Sponsored by:
Sponsored by: DashLynx
Vacum line replacement
Old 01-11-2011, 10:55 PM
Modidy
Modidy's Avatar
Default Vacum line replacement
I am new here, and did try the search first, but could not find the information I was looking for. I recently purchased a 04 GT convertible. In the process of doing a tune up, while replacing the PCV valve, I tore a severly dry rotted vac line the connects under the upper intake manifold section. I believe it's the line that runs to the charcoal canister... anyway, it broke off at a point under the upper manifold.
My question: Do I have to remove the upper intake manifold to install a new line? I have big hands, and can't get them in there far enough to feel the nipple it goes back on. Is there an easy way of replacing that line without removing the upper intake? It's making the car run a little rough from the vac leak.
Any and all help would be appreciated,
Thanks,
Mo
Modidy is offline
Old 01-12-2011, 03:22 AM
petrock
petrock's Avatar
You could try a set of needle nose or hose puller pliers. Good luck...
petrock is offline
Old 01-12-2011, 06:59 AM
Modidy
Modidy's Avatar
Thanks,
Mo
big ooops in my post... it's a 94, not 04... wishful posting I guess
I will try the needle nose, but there doesn't seem to be enough room to get the angle needed.
Modidy is offline
Old 01-13-2011, 01:37 AM
petrock
petrock's Avatar
You could get a longer set of pliers. There are even angled sets you could pick up. However, its fairly simple to pull the upper intake. A new gasket is pretty cheap, and some would even re-use the original if it is still in good shape.
petrock is offline
5.0muscle
01-11-2016 01:17 PM
StalkerGT
09-25-2015 02:41 PM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
09-08-2015 11:50 AM
Quick Reply: Vacum line replacement
