Sponsored by:
Sponsored by: DashLynx
Button Under Dash?
Old 05-07-2012, 10:56 AM
157dB
Cut & Paste Expert
157dB's Avatar
Seems this the starter interrupt someone has installed has taken over....
157dB is offline
Old 05-07-2012, 01:04 PM
ttocs
ttocs's Avatar
as he said it looks like the starter kill that was installed has now turned on, or the wiring to it has become disconnected. Often on a starter kill there is an offboard relay that the starter kill controls. Look up around the ignition wiring or again in the kick panel for the relay and check the wiring going to it.
Or call the dealership as it could be a good pia to hunt down what has happened.
ttocs is offline
Old 05-07-2012, 03:10 PM
rooky_07
rooky_07's Avatar
I have a button on my 95 in a similar location. It is for the starter kill relay for the factory alarm system. If it won't crank, turn the key on, hit the button and try again. Could well be a dealer installed alarm.
rooky_07 is offline
Old 05-07-2012, 06:18 PM
chemoman
chemoman's Avatar
I tried that. pressed with the key on, key off, key out...
As far as the dealer installed alarm:
The dealer told me today that it could be a "lot alarm" installed. An alarm that the dealer installs for their security and if the buyer doesn't want it they pull the module. I was never told anything about it. Plus, I have never noticed it until now. I guess it could be possible that I have overlooked it all these years. My wife has been the primary driver until last month and she took it to detail shops for cleaning.
Any thoughts on this "lot alarm" idea?
chemoman is offline
Old 05-08-2012, 02:19 AM
ttocs
ttocs's Avatar
factory alarms do not use add-on modules like that that screw into the panel, this was definitly an add-on aftermarket alarm.
Having installed audio/security for 10+ yrs I can tell you that lot alarms are the worst thing you can imagine. They contract out to the lowest bidder normally, that uses the cheapest products and then wants to spend as little time as possible in each car. I know people that could literally be in/out in 10 mins but they would not do it to their own car and you would not want it done to yours. Good news is that they are easy to pull out. Follow each wire from that alarm hrns till it ends and cut it and insulate all the bare copper. It sounds like alot but would probably take a diy'er 45 mins.
ttocs is offline
Old 05-09-2012, 01:03 PM
chemoman
chemoman's Avatar
I just had the shop tech remove it while he was in there screwing me......I mean fixing the other problem. At least now I don't have to worry about it.
Thanks for everyone's.
chemoman is offline
Old 05-18-2012, 11:06 AM
157dB
Cut & Paste Expert
157dB's Avatar
+1
Also I have been installing car alarms for 30 years as well.
Git rid of that scotch locked nightmare that wont start.
157dB is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
07-05-2020 03:05 AM
firehorse02
11-16-2015 11:28 AM
lincolnshibuya
10-06-2015 08:45 AM
09-30-2015 12:39 PM
Quick Reply: Button Under Dash?
