Sponsored by:
Sponsored by: DashLynx
Jerking badly after tune up
Old 05-08-2012, 11:36 PM
Fatboi
Fatboi's Avatar
Default Jerking badly after tune up
Ok so I did a tune up probly the 2nd one this car has ever seen I have a 94 mustang gt 5.0 ho engine. After the tune up it started "puddering" and my oil temp light reads 0 when I stop and shakes a Lil more then usual. When I accel it goes away but when I cruise around it pudders and seems like its missing but I don't see how it could be cause it was running fine for about a hour Ish then this started it happen. I changed the plugs wire dist cap and rotor. I'm thinking it's the coil messing up or old but idk any advise I can do to get this car running right again
Fatboi is offline
Old 05-10-2012, 11:54 PM
nightwing0707
nightwing0707's Avatar
i had something similar in my dads f150 it ended up being a faulty spark plug changed it and problem solved, you might want to check that all spark plug wires are connected all the way. did a check engine light come on?
nightwing0707 is offline
Old 05-11-2012, 01:18 AM
JC316
JC316's Avatar
Did you hook the plug wires up in the correct order? Usually this is the cause.
JC316 is offline
articman
06-21-2018 11:45 PM
09-08-2015 06:25 PM
zanemoseley
09-06-2015 12:58 PM
Emblazoned
09-03-2015 10:45 PM
whatsup62
09-03-2015 01:38 PM
Quick Reply: Jerking badly after tune up
