Boost Sensor Problem for 09 GT
So I have an 09 Mustang GT and I have been screwing around with this boost sensor I got for my aeroforce interceptor gauges. The gauges seem to work but it will not read my boost. I set up everything correct and the wires are spliced to the correvt 5v power source. The 5v power source is coming from the brown sensor wire on the fuel rod on the driverside by the way. I could get that 5v source thing from aeroforce but there has to be another 5v power source on the car. Does anyone know of one or has anyone else had a similar problem to mine because I feel like I am the oonly person out there dealing with this? Thanks
I was told to use the O2 sensor, but I decided to purchase the 5V power supply. I wired it to the fuse box, and ran the wires along the firewall. I'm running a analog fuel pressure sender to my aeroforce gauge and a Procharger mechanical boost gauge. The 5V power supply is very small and can be hidden. I suggest you purchase it instead of cutting into your other lines.
Galactic
04-29-2019 02:56 PM
TfcCDR
09-14-2015 12:08 PM
