Sponsored by:
Sponsored by: DashLynx
88 5.0 HO fires on #8 only
Old 12-26-2012, 02:19 PM
amgentry
amgentry's Avatar
Default 88 5.0 HO fires on #8 only
I have an 88 5.0 HO that will not start. I have replaced Coil, cap, button, and complete distributor including TFI module. If I take off the coil wire from distributor and ground it it throws good sparks. If I plug it back to distributor I get fire to only cyl #8. I have been messing with this for days and I am lost!!! Help.........
amgentry is offline
Old 12-27-2012, 12:20 PM
clowe1965
clowe1965's Avatar
I think you've probably done this, but are all the spark plugs good as well? Wasn't listed in your replacement list. Were you having this problem before you replaced any of the components? Check that all the plugs are torqued in the holes correctly to ensure a good ground. Also check that the plug wire tab is actually on the spark plug and not just the boot slipped over it. I've done that a couple of times.
clowe1965 is offline
Old 01-03-2013, 11:22 AM
GeigerZ
GeigerZ's Avatar
Is the rotor turning when you have the dizzy cap off and spin the motor?
Dizzy 180* off?
GeigerZ is offline
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: 88 5.0 HO fires on #8 only
