Sponsored by:
Sponsored by: DashLynx
2003 mustang mach 1 compression
Old 03-16-2013, 10:30 PM
racerkyle88
racerkyle88's Avatar
Default 2003 mustang mach 1 compression
i did a compression test on my 2003 mustang mach 1 it has about 130,000 miles on it. dry test i got results of 140-145 all the way around. on the wet test i got results of 160-175 all the way around. does anyone know what the spec should be per cylinder. according to a ford tech ford company never put out a actual spec per cylinder and he said he thinks it should be around 200-220. i think thats a little high. does anyone know for sure? thanks
racerkyle88 is offline
Old 03-17-2013, 05:01 PM
petrock
petrock's Avatar
Compression will start to go down the first time the motor is run, and continue to go down as the miles tick on. So there is no way to accurately provide a spec. It may have been 200-220 when it rolled off the assembly line, but 130k miles will lower that. The numbers you have look good to me. The key is that they are all within about 10% of each other, which they are in your case.
Good luck...
petrock is offline
daytooday
05-02-2018 05:56 PM
SANDY21
08-17-2015 02:41 PM
iamgobono
08-16-2015 10:50 PM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 2003 mustang mach 1 compression
