Sponsored by:
Sponsored by: DashLynx
393 Windsor (Header size???)
Old 03-25-2013, 05:40 PM
Winekuhler
Winekuhler's Avatar
Default 393 Windsor (Header size???)
I am fixing to order a set of headers and I am wondering what size to buy and whats the best? I am running a 393 Windsor with a .680 solid roller cam and AFR Renegade 220 heads with the 58cc combustion chamber. Max RPM is 7,000. Should i go 1 3/4", 1 7/8" or 2" primaries into a 3 or 3 1/2" collector? What name brand do you suggest for the best performance? Thanks for all help and suggestions.
Winekuhler is offline
Old 03-26-2013, 12:01 AM
tinman
tinman's Avatar
I'd try for a step header going from 1 3 /4 to 1 7/8.
Call Accufab in California ask for George Klass, he knows what he's doing with stuff.
Be ready to spend money however.......
tinman is offline
Old 03-27-2013, 08:09 PM
Winekuhler
Winekuhler's Avatar
Default Thanks
Thanks Tinman. I went with a set of KOOKS 1 7/8" stainless steel headers from Jegs. Some friends i have talked to have said they are supposed to be some of the best out there. We will see, they also have a lifetime warranty.
Old 03-27-2013, 08:40 PM
Mike T
Mike T's Avatar
You'll probably still need to clean up the welds inside the flanges with a carbide de-burring bit for unrestricted flow. I did this on a set of BBK's I just bought.
Mike T is offline
Old 03-28-2013, 01:32 AM
tinman
tinman's Avatar
Do you have to run special spacers or something due to the 1 7/8 tube size?
What is the bolt spacing on that head for the header flange?
tinman is offline
Old 03-28-2013, 07:18 PM
Winekuhler
Winekuhler's Avatar
It has a 3 inch bolt spacing. They are supposed to be a direct fit specifically made for the AFR.
JayGee
09-15-2015 12:41 PM
BrantleyS550
09-14-2015 04:18 PM
09-10-2015 08:39 PM
Other Professional Racing
09-10-2015 11:41 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: 393 Windsor (Header size???)
