Sponsored by:
Sponsored by: DashLynx
Baer bumpsteer kit yes no?
Old 06-24-2013, 06:29 PM
br.m.94
br.m.94's Avatar
Default Baer bumpsteer kit yes no?
ok i have a 72 mustang with a 302 in it. I lowered it quite a bite (heated springs i know i know ) but since i lowered my car and changed the geometry of it my bumpsteer is crazy! i can not go on the freeway because it will dart in whatever direction it wants to! i know its the roads fault partially but it also has to be the suspensions fault also so my solution?
THIS:
http://www.cjponyparts.com/baer-bump...0-1973/p/BSK3/
will it solve my problem? or maybe at least make it better? my suspension is stock with new parts except the springs will this kit eliminate bumpsteer???
my car is pretty low..not really really low but its low how will this react?
br.m.94 is offline
Old 06-25-2013, 06:00 AM
petrock
petrock's Avatar
By heating your springs when you lowered them you weakened them considerably. They will be a lot more bouncy, which will contribute to bump-steer and wear out your struts/shocks fairly quickly. I’d replace the springs with real lowering springs. That would probably get rid of the majority of your issues. Good luck...
petrock is offline
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
flash_xx
10-16-2015 07:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: Baer bumpsteer kit yes no?
