Sponsored by:
Sponsored by: DashLynx
Sensitive brake light
Old 03-13-2014, 06:30 PM
Bertamus47
Bertamus47's Avatar
Default Sensitive brake light
I have a 2010 mustang gt with stock brakes. My brake light is activated when hardly any pressure has been put on the pedal. As a result, my buddy tells me that that light flashes on momentarily when I hit a bump or even downshift. Is there an easy way to adjust the brake light engagement point? Sorry if this question has already been answered.
Thanks
Bert
Bertamus47 is offline
Old 03-13-2014, 08:57 PM
steel pony
steel pony's Avatar
Thanks
Bert
Whens the last time you checked the fluid level?
Not sure about the light engagement, but it sounds like the system is reading either an engagement of the braking system or low fluid, which could be a pinhole leak causing air to get in the line or possibly the e-brake line is not fully released from the rear brakes
steel pony is offline
Old 03-14-2014, 06:46 AM
88 orangepeel notch
88 orangepeel notch's Avatar
I'm not familiar with the newer mustangs, but look at the brake pedal arm, there should be a switch there that has a threaded body for adjustments.
88 orangepeel notch is offline
Old 03-15-2014, 09:24 AM
Bertamus47
Bertamus47's Avatar
Ok thanks for the help. Im pretty sure the fluid level is fine, and there has been no loss in brake feel or engagement, but I'll check anyway as well as look for some kind of adjustment.
DoctorScary
09-09-2015 07:53 AM
09-08-2015 11:50 AM
whatsup62
09-03-2015 01:38 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: Sensitive brake light
