302 to blown 5.4 swap
I have the chance of a 5.4 supercharged motor from a f150, would i be able to replace a 302 with it?? will it have the same bellhousing pattern as a 302, any help or advice would be welcome, Thanks
I'm going to assume you have a Fox/SN Mustang. Now I'm not the most knowledgeable on this, but a 5.4 is a lot wider than a 302, I can't see it fitting in there without a lot of modification. Someone correct me if I'm wrong. Also the bell housing pattern will be different, but they make adaptor plates for almost anything.
bradleyb
11-27-2015 07:50 PM
Matt's 95 Stang
10-05-2015 07:16 AM
