Sponsored by:
Sponsored by: DashLynx
Idling problems, timing problems, running rich...
Old 04-18-2015, 07:05 AM
CyprusMustang
CyprusMustang's Avatar
Default Idling problems, timing problems, running rich...
I just changed head gaskets and had the heads ported as I was getting pressure in coolant and overheating. Turns out a piece of head gasket went out and was leaking.
Anyway I had the heads pressure tested for cracks and Vaccum tested for leaky valves turns out all ok.
I install them back to the car and car doesn't ovwrheat anymore and coolant flows nicely. However I'm trying to get the idle perfect and I cant. I always had an issue with the idle. I purchased a vacuum guage from here but it's in bar and reads .0 to .8. The needle bounces rapidly back and forth from .6 to .7 which is 17.5 to 20.5 inches Hg.
I played with the timing and it seems to run best at around 16-17 degrees on the balancer.
There is a mid range cam installed, it's a 302 with edelbrock 600 carb, slightly higher aluminum intake manifold, it's been bored over once and has Patriot long tube headers.
Not sure what else I can test or try out. Any ideas guys?
CyprusMustang is offline
djbigskrilla
09-20-2022 01:04 AM
1987gt40ttopt
08-28-2015 10:49 PM
fdnyems19
08-13-2015 09:36 AM
stanngg
08-12-2015 03:43 PM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: Idling problems, timing problems, running rich...
