Sponsored by:
Sponsored by: DashLynx
Problem with 01 gt please help
Old 07-20-2015, 09:06 AM
Gypsychild
Gypsychild's Avatar
Default Problem with 01 gt please help
Hi I am new to this but need all the help I can get I just got a 01 mustang get and I new I had to replace the filler neck and gasket going into fuel tank cause when fill it can smell gas for a few min and it will leek out a little and the ses light came on and gave an Evap code but had to get towed yesterday and I don't know if it is iac alternator or fuel filter. Was driving just fine all day then it started jerking pretty good and then would lose all power after a min or two it would fire up drive fine for a few more min and did it again but if I pull over befor it shut down on me and put it in park it continued like it was gonna stalk out and the rom would jump from nothing to 1 any ideas or thoughts thanks
Gypsychild is offline
Old 07-20-2015, 08:57 PM
HACKGT350
HACKGT350's Avatar
have you tried pulling codes from the computer?
HACKGT350 is offline
Old 07-20-2015, 09:01 PM
Gypsychild
Gypsychild's Avatar
I have not tryed again only happened last night but like I said I new it was throwing an Evap code not sure exactly witch one but figured it was due to the filler neck and gasket needing replaced
Old 07-20-2015, 09:04 PM
HACKGT350
HACKGT350's Avatar
yeah that is why the evap code came on. i would scan it again and see if it has set any other codes. if it were the alternator you wouldnt be able to start the car back up as the battery would run the electrical system until it drained the battery.
Old 07-20-2015, 09:06 PM
HACKGT350
HACKGT350's Avatar
also if it were the idle air control valve it would have a problem idling not driving, hence the name IDLE air control valve
Old 07-20-2015, 09:10 PM
Gypsychild
Gypsychild's Avatar
Well it starts jerking and idling rough that's why I though that I'll check the codes again and see what happens if it throws anything new
Seanam
10-04-2015 10:15 AM
mdj89
09-23-2015 08:49 AM
kachuy10
09-22-2015 01:27 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: Problem with 01 gt please help
