Sponsored by:
Sponsored by: DashLynx
Headlights/bulbs advice
Old 05-17-2016, 03:00 PM
StangMuscle
StangMuscle's Avatar
Default Headlights/bulbs advice
Hey guys,
Need some advice on which headlights/bulbs to go with.
I have tried:
Stock lights
Stock headlights with HIDs
Raxiom style projectors with HIDs
So far the best setup has been stock headlights with hids (but it was definitely blinding to others.) I love the look of the Raxiom headlights, but the visibility is terrible. My fogs (hids), are 10x brighter and dont blind other drivers being behind my grill. Plus the plastic piece that bolts the headlights to the cars frame broke, so the light shifts with every bump on the road!
Im looking for input on what direction I should go.. I would love to keep the aggressive look (halo!) of the raxioms, but ultimately visibility is far more important to me.
A buddy of mine recently went LEDs in his truck, and they look great.. Any input on these in a stock housing? Or has anyone found a GOOD set of projectors!?
StangMuscle is offline
Old 05-17-2016, 05:55 PM
Soldier GT
Soldier GT's Avatar
Check out the DDM tuning.
Soldier GT is offline
Old 05-20-2016, 01:36 PM
Z28KLR
Z28KLR's Avatar
I have PIAA brand 9007's in aftermarket (stock style) housings, they are supposed to be a 5000K light temperature and higher wattage (55/100) than most others like Silverstar's etc (35/55 typically).
They are stupid bright, comparable to the 6000K hid's I have in my Sport Trac. I probably need to re-aim them downward just a hair as they do **** off about 2 or 3 out of every 10 oncoming vehicles.
Anyway I've been very happy with them, if you don't want to go back to hid then that's what I recommend. Kinda hard to find in stores but you can look them up on Amazon, they go for about $75/set.
Z28KLR is offline
Old 05-21-2016, 03:28 PM
StangMuscle
Exclamation
I love HIDs, but my car is already a cop magnet as it is. And from what ive found, the only good projector headlights are custom made and quite pricy. Im considering it, but also exploring my options.
Hows your cutoff in the stock assembly? Do you use the cup reflector thing, or did you push it out of the way?
Thanks for the input!
Old 05-22-2016, 12:18 PM
Z28KLR
Z28KLR's Avatar
Yeah I use the "cup reflector" thingy. My housings are exactly the same as stock but with clear turn signal reflectors instead of amber. Light cutoff/beam pattern is exactly the same as any other halogen lamp. HID's, as you know, in a non-HID housing tend to aim more like flood lights which is what pisses off other motorists. That can still usually be fixed or at least minimized by aiming the housings downward a little.
Z28KLR is offline
Old 05-22-2016, 03:31 PM
StangMuscle
Awesome! If I don't end up going the custom projector way, I think I will be going the same route as you.
I recently got pulled over for using my fogs in "non inclimate conditions." Which is a total BS law, (the cop said it himself!) and was probably just a crappy excuse to find other citeable offenses.. Still a good enough reason for me to get my headlight issue addressed. Still sucks though, cause my fogs light up the road perfectly.
trackers
04-26-2016 05:29 PM
JMikk
03-18-2016 02:46 PM
clowe1965
Carolina Regional Chapter
03-13-2016 04:02 AM
Heatleymvp
03-05-2016 12:09 AM
Drastang
02-20-2016 10:54 AM
Quick Reply: Headlights/bulbs advice
