TCI Ratchet Shifter Install
Old 08-12-2010, 03:30 PM
  #81
Casey4s
Casey4s's Avatar
Originally Posted by Sniper308
Is it possible to shorten the two "sticks" so they're about the same height as the current shifter?
Russ
I shortened the toggle shaft about 3/8" to make it lower than the shifter handle. You can shorten the other shaft by trimming the top down to the size of the threaded part and then re-thread it. I though tabout it but it seemed too risky to try.
Actually I really like the height of the shifter now that I have had it installed for more than a year and don't plan to cut mine down anymore.
Here's where I cut the toggle shaft...
You can see it changed the height relationship of the two shafts.
Casey4s is offline
Old 08-12-2010, 08:26 PM
  #82
Sniper308
Sniper308's Avatar
Thanks, Casey, for the quick reply AND the photos. Sure helps to see it. Looks good, too, I might add.
Russ
Sniper308 is offline
Old 08-13-2010, 01:37 PM
  #83
Casey4s
Casey4s's Avatar
Russ
Thanks Sir...
EDIT:
I just remembered! When you change the height of the shaft the little screw in the back doesn't line up with the hole anymore. The quck and efficient cure is to drill and tap that hole in the toggle for a set screw. I used a 1/4 x 16 x 1/4, 3/16 length would be better. It willl "pinch" the toggle securely to the shaft anywhere. You can get the drill & tap and set screws at Lowes among other places.
There are some more photos at this PhotoBucket link. >>>---> http://s238.photobucket.com/albums/f...gle/?start=all
Casey4s is offline
Old 09-06-2010, 07:53 PM
  #84
rmagni
rmagni's Avatar
Default shifter
Great write up great photo's shifter looks awesome!
Robert
rmagni is offline
Old 11-21-2012, 08:44 PM
  #85
Troy Perry
Troy Perry's Avatar
I have a 2006 v6 mustang. my shifter still works but the cover around it pops up every so often. if i take the console apart i can fix it but seems like it is happening more and more frequent. I am not a car guy but can do some stuff. to me it seems like the Black sliding part is jumping the track and getting stuck thus not allowing me to put it in park. I use to just stuff it back in the track and it would work for a bit but after it happens like 1 time a week i just cut it off. the problem is still happening though. and since i love my mustang and dont want to look trashy i think i am just going to replace the whole shifter. Does anyone know where i can buy a factory shifter? seems like the TCI shifter is only one out there. and if I took it to the Ford place how much do you think they would charge me?
troy
Troy Perry is offline
Old 11-22-2012, 02:39 PM
  #86
Goldenpony
Goldenpony's Avatar
First off, I'm not trying to ba a -ick. As a stick shift driver, I understand why people replace the mediocre factory shifter with a 5 or 6 speed tranny. I don't understand what you get by replacing the shifter with an automatic. Exactly what do you gain?. Like I said, I'm not trying to be a smart ***, I am just curious.
Goldenpony is offline
Old 11-22-2012, 06:02 PM
  #87
jpplaw
jpplaw's Avatar
I don't run one, but it is basically so you can shift like a stick without the danger of hitting the wrong gear.
And there is the aesthetic component as well. The stock auto shifters are all plastic, and not that pretty.
jpplaw is offline
mtgldr
02-03-2024 09:00 PM
carid
07-08-2016 09:55 AM
poke68
12-15-2015 06:25 PM
robjh22
Suspension
09-08-2015 12:47 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: TCI Ratchet Shifter Install
