Low Battery -- Can't Get Window to Recalibrate
The TSP procedure worked perfectly. You have to disconnect either the battery or pull the fuse while operating the window. I didn't want to disconnect the battery, so I pulled the fuse first, then just barely reinserted it enough to make contact. Then it was easy to pull during the procedure.
Thanks to 157db!
John
Thanks to 157db!
John
jwog666
12-27-2021 08:09 PM
logan409
09-26-2015 07:43 PM
