S197 2007 tire pressure sensor
Old 02-14-2012, 05:24 PM
TinPony
TinPony's Avatar
Default S197 2007 tire pressure sensor
Can anyone offer advice on trouble shooting a "tire pressure sensor fault" code on my display..
TinPony is offline
Old 02-14-2012, 08:18 PM
danzcool
danzcool's Avatar
Other than the basic "did you check the tire pressure", and the "try reprogramming it (need the programming tool), I've heard that the battery life on the sensors is about 5 years. American Muscle has the tool and replacement sensors at a reasonable price.
danzcool is offline
Old 02-14-2012, 10:39 PM
Diabolical!
Diabolical!'s Avatar
My F150 had a problem with the tire pressure dummy light coming on even though all four tires were properly inflated. I fixed it with a small piece of black electrical tape.
Diabolical! is offline
Old 02-14-2012, 10:45 PM
SoCalGT08
SoCalGT08's Avatar
where are those sensors located on the car ?
SoCalGT08 is offline
Old 02-14-2012, 10:46 PM
TinPony
TinPony's Avatar
Thanks guys.... got it figured out. After reset you must drive a few miles and it's good.
TinPony is offline
Old 02-15-2012, 02:00 AM
Lem-06
Lem-06's Avatar
in the tires wrapped around the rims one would assume
Lem-06 is offline
Old 02-15-2012, 10:40 AM
ironh19
ironh19's Avatar
I was going to say last time I had the battery disconnected, I had the same fault show up, just drive around a few miles and it will correct itself.
ironh19 is offline
Old 02-17-2012, 11:22 AM
157dB
Cut & Paste Expert
157dB's Avatar
http://iihs.net/fsm/?dir=68&viewfile...g%20System.pdf
Attached Thumbnails S197 2007 tire pressure sensor-tpms2.jpg   S197 2007 tire pressure sensor-tpms.jpg   S197 2007 tire pressure sensor-tpms3.jpg
157dB is offline
Old 02-17-2012, 12:22 PM
TinPony
TinPony's Avatar
Thanks 157db... you really are a cut and paste expert.... you are permanently on my friend list...
TinPony is offline
Old 02-18-2012, 10:37 AM
157dB
Cut & Paste Expert
157dB's Avatar
So many images, so many questions, so little internet time...
157dB is offline
Jb145700
08-21-2022 06:37 AM
SteelerNation82
09-16-2015 07:11 AM
TfcCDR
09-14-2015 12:08 PM
09-08-2015 11:50 AM
Webster454
09-07-2015 04:59 AM
Quick Reply: S197 2007 tire pressure sensor
