Built all motor 3V
Old 10-05-2012, 05:47 PM
  #21
danzcool
danzcool's Avatar
Originally Posted by 0gmstucke
What site can i find a electric water pump? I dont think A&M has it
you can get it from brenspeed, most estimates are that it is good for 5-10 hp.
http://www.brenspeed.com/wp346s.html
danzcool is offline
Old 10-05-2012, 06:34 PM
  #22
siggyfreud
siggyfreud's Avatar
I understand that i said 6800 in reference to a previous post. But the articles I have read said that it was done at stock rev limit. So thats why i was initially asking if anyone had first hand experience with the build to see how accurate the info was
With more power on tap at a lower RPM, you'll need to hit 6800 less often to achieve the same results. That is where you gain back ground on motor longevity. It you're hitting redline 20 times per day NA as well as boost, the longevity difference of the motors probably isn't that big of spread. That said, Corky Bell theorized that added boost pressure actually helped negate rod stretch at higher RPM, thus having boost in there was safer in that regard.
siggyfreud is offline
Old 10-06-2012, 09:24 PM
  #23
808muscle
808muscle's Avatar
Everything I have read states its much cheaper to get to 400 HP via a blower vs N/A. In the end you gotta have a budget.
808muscle is offline
Old 10-07-2012, 09:24 AM
  #24
0gmstucke
0gmstucke's Avatar
[QUOTE=808muscle;8066331]Everything I have read states its much cheaper to get to 400 HP via a blower vs N/A. In the end you gotta have a budget.[/QUOTE
The route I would go if I chose FI would be the Edelbrock E-force blower which if im not mistake is about $5000. So I will spend a little over that on parts I will be saving big $$ because I install everything myself. But this is slowing turning into a project car where about the only things stock when im done with it is the body itself. I like all engine monsters and that is why I want to build a N/A 4.6 3V that is going to surprise a lot of people. The 3V 4.6 builds torque very well when modded NA and that is why I think I will have quite a bit of fun with it.
0gmstucke is offline
Old 10-11-2012, 01:57 AM
  #25
drewsky
drewsky's Avatar
Correct me if I'm wrong but I think 400 rwhp is pretty tough on a 3v non FI.. Heads cams intake manifold full exhaust... Still don't see those numbers
drewsky is offline
Old 10-11-2012, 09:27 AM
  #26
TRexGAWD
TRexGAWD's Avatar
You are correct.. It's a pretty difficult task and it's not gonna be the most street friendly car at all..
TRexGAWD is offline
Old 10-12-2012, 06:34 PM
  #27
Chevy Convert
Chevy Convert's Avatar
Cut the bs and just go FI. You will save serious cash and have a better car all around. If N/A is a must go with a coyote. The 4.6 is a great little motor....operative word little. The 5.0 is too but a lot better air pump.
Chevy Convert is offline
lincolnshibuya
10-06-2015 08:45 AM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Drastang
09-30-2015 03:48 AM
logan409
09-26-2015 07:43 PM
Quick Reply: Built all motor 3V
