Alternator talk...
Old 03-12-2014, 08:34 PM
luvmygt
luvmygt's Avatar
I picked up the PA performance one for my 2006 and it was worth every penny. I wish I could find one for my 2014.
luvmygt is offline
Old 03-12-2014, 10:37 PM
Goldenpony
Goldenpony's Avatar
Originally Posted by AMShaneLesky
The SR does not have a lifetime warranty. However, if you have any issues with it shortly after use, we'll stand behind the product and replace it. As we do with all of our parts!
The one way clutch really just helps with engine deceleration, by preventing belt slip. Honestly it's really minimum and not necessary. Most cars don't use one and they operate perfectly. Tools can be bought to make the pulley swap easier, as you see linked above.
Shane
Because of the lifetime warranty, when I do buy I will go with the PA. Thanks.
Goldenpony is offline
Old 03-12-2014, 10:38 PM
Goldenpony
Goldenpony's Avatar
What was the best improvement?
Old 03-13-2014, 09:50 AM
luvmygt
luvmygt's Avatar
Over time my sub and amp would kill the OEM alternators. I think I ran through 4 of them before I got my act together. Ordered the Pa performance one from American muscle, it showed up within 2 days, and I never had another electrical issue with my car.
luvmygt is offline
Old 03-13-2014, 12:16 PM
Goldenpony
Goldenpony's Avatar
Gotcha! Thanks.
Old 06-12-2015, 05:55 PM
Rubicon
Rubicon's Avatar
Originally Posted by AMWill
Goldenpony,
The black centered pulley on the SR Performance alternator is just a black plastic cover. It covers the pulley bolt and prevents grime from entering. It's just to keep a cleaner look to the alternator after long term use.
Either of SR Performance or PAPerformance alternators will work well for a stock replacement. Technically the SR Performance is an "upgrade" since it's 5amps larger than stock, but a minimum upgrade at that.
Let me know if you have other questions!
Shane
So I can take off my stock alternator with the clutch and replace it with either of the alternators from AM with no clutch and have no issues? I am replacing because of P0340 and Advanced Auto tested the stock one and it said Open Diode
Rubicon is offline
Old 06-12-2015, 08:25 PM
Goldenpony
Goldenpony's Avatar
I replaced my OE alternator with a clutch with a PA without a clutch. I don't see any difference at all.
Old 06-25-2015, 08:06 PM
richmod
richmod's Avatar
Do I need to buy the AM power wire with the PA alternator, or can I use the stock wiring?
richmod is offline
Old 06-25-2015, 09:21 PM
bl817
bl817's Avatar
you can use existing wires unless your wanting more power somewhere else. search "big 3 upgrade". wouldn't hurt to upgrade any or all. good luck
bl817 is offline
Old 07-02-2015, 10:04 PM
Goldenpony
Goldenpony's Avatar
When I replaced my OE alternator with the PA, I did also install the PA power wire. Figured, why not go all the way.
4cylinderplus2
10-09-2020 07:45 PM
Golfsito
10-06-2015 11:02 AM
MasterLanMan
09-26-2015 10:03 AM
Wombatnation
09-13-2015 09:16 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: Alternator talk...
