moisotor in reverse light lense what should i do?
Old 11-26-2014, 01:28 PM
RenGen
Banned
RenGen's Avatar
Default moisotor in reverse light lense what should i do?
i got these raxiom smoked tail lights maybe a month or so ago and from what i can tell i did install them tightly and properly, but notice moisoture in my reverse lense now
what can/should i do?
RenGen is offline
Old 11-26-2014, 01:32 PM
Derf00
Gentleman's Relish
Derf00's Avatar
send them back to wherever you got them from for a warranty exchange and then seal the edges of the new lenses with "clear windshield RTV"(Permatex #80050) to make absolutely certain the things are sealed.
Derf00 is offline
Old 11-27-2014, 09:19 AM
kingstrider
kingstrider's Avatar
Bummer, can these be taken apart and resealed?
kingstrider is offline
Old 11-27-2014, 10:10 AM
RenGen
Banned
RenGen's Avatar
I have removed the tail light - i noticed it was a little loose, and i re installed it nice and tight.
should the water be able to dry out in time and evaporate through the lens? or will it be trapped in there forever?
RenGen is offline
Old 11-27-2014, 02:57 PM
2000AZ5.0GT
2000AZ5.0GT's Avatar
Sure looks a lot more like moisture, but I guess I don't know what the hell moisotor is.
2000AZ5.0GT is offline
Old 11-27-2014, 04:41 PM
RenGen
Banned
RenGen's Avatar
It's like moisture, but more moisot.
RenGen is offline
Old 11-28-2014, 07:55 AM
Moderator
JimC's Avatar
Thread cleaned, play nice people.
JimC is offline
Old 11-29-2014, 11:11 AM
157dB
Cut & Paste Expert
157dB's Avatar
Looseness with the mounting hardware will not
cause a properly sealed light fixture to leak.
Each bulb holder should seal up tight with
a rubber gasket. The rubber vent grommet
should also be present and intact.
Replace the light housing, make sure the
bulbs are it tight and sealed and all
should be well...
157dB is offline
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
lincolnshibuya
12-08-2015 04:37 PM
Explosive
10-02-2015 07:45 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: moisotor in reverse light lense what should i do?
