Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
2000 3.8 to 4.6 swap
Old 12-05-2014, 10:00 AM
mmmdaddy57
mmmdaddy57's Avatar
Default 2000 3.8 to 4.6 swap
Will the 4.6 engine fit on the stock K-member, or are the mounting points on the stock K-member in a different place?
mmmdaddy57 is offline
Old 12-05-2014, 10:35 PM
ticopowell
ticopowell's Avatar
I am not 100% sure, but I think that the K-member and motor mounts are the same, it kept things easier and cheaper for Ford.
if you have both motors you can measure the distances, if not I would look at aftermarket k-members and see if there are specific part numbers for v6 and v8 motors.
ticopowell is offline
Old 12-07-2014, 09:31 AM
mmmdaddy57
mmmdaddy57's Avatar
Default Front end swap
Thanks ticopowell. I tried to look it up that way but They didn't list any. I as called 2 of the aftermarket K-member companies like QA1. They said they didn't have one and didn't know if it would work. I bought a K-member anyway I am just trying to get ahead of things before I take the front end out. If it doesn't fit I can fabricate it to work since I have a mig welder. When I get the answer I will post it on the site.
Old 12-07-2014, 09:32 AM
mmmdaddy57
mmmdaddy57's Avatar
I am not installing a 4.6 I just need to know if the K-member listed for the 4.6, will fit with my 3.8.
Old 12-08-2014, 05:36 PM
PNYXPRESS
PNYXPRESS's Avatar
Please post what you find out about the k-member. If the 3.8L block mounts up it will be easier than trying to fab one up.
PNYXPRESS is offline
Old 12-10-2014, 09:22 AM
LilRoush
LilRoush's Avatar
K member is the same, engine mounts are different.
LilRoush is offline
Old 12-10-2014, 06:49 PM
mmmdaddy57
mmmdaddy57's Avatar
Thanks Lilroush
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mrappe
09-26-2015 10:16 AM
col2560
09-25-2015 08:59 PM
Quick Reply: 2000 3.8 to 4.6 swap
