1966 mustang engine energized
Old 01-13-2014, 05:28 PM
rjames1316
rjames1316's Avatar
Default 1966 mustang engine energized
hi all i have a 1966 mustang that i put on a carb and adjusted the timing on jack stands running nicely. when i took car off jack stands to back out it wouldnt start went click. Battery is good 12.7 now the problem is everything is energized. I took a test light to carb and it lights up " yes it is hooked to neg on battery side and point to carb" the whole car is energized here is what we have done.
1 removed starter solenoid tested it works good
2 removed ignition switch still hot
3 remove light switch still hot
4 voltage regular still hot
5 unhooked distr still hot
6 starter still hot
the only time we loose light is disconnecting main power from firewall, and when we pull the dome fuse with ignition switch out as soon as the ignition switch is hooked up engine is hot any help we havent tried
rjames1316 is offline
Old 01-14-2014, 06:33 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Welcome, but I would post this question in the appropriate tech forum, you'll get alot more answers. This forum is for new members to introduce themselfs.
But I'd start at checking the grounds, and ground cable. 1 bad cable or connection can really screw with your car. Good luck
88 orangepeel notch is offline
Old 01-14-2014, 06:41 AM
05 Mustang
05 Mustang's Avatar
welcome & good luck!
05 Mustang is offline
Old 01-14-2014, 07:11 PM
2005Redfire6
2005Redfire6's Avatar
Welcome
2005Redfire6 is offline
Old 01-14-2014, 07:36 PM
GHJA614
GHJA614's Avatar
welcome!
GHJA614 is offline
Old 01-16-2014, 08:00 AM
96t-bird
96t-bird's Avatar
Welcome.
96t-bird is offline
Old 01-18-2014, 06:09 PM
Getsome19
Getsome19's Avatar
Welcome
Getsome19 is offline
ShaneB26154
35
03-04-2021 04:05 AM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
KEM Motorworks
08-14-2015 10:13 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 1966 mustang engine energized
