01 mustang Gt please help
Old 07-20-2015, 09:08 AM
Gypsychild
Gypsychild's Avatar
Default 01 mustang Gt please help
Hi I am new to this but need all the help I can get I just got a 01 mustang get and I new I had to replace the filler neck and gasket going into fuel tank cause when fill it can smell gas for a few min and it will leek out a little and the ses light came on and gave an Evap code but had to get towed yesterday and I don't know if it is iac alternator or fuel filter. Was driving just fine all day then it started jerking pretty good and then would lose all power after a min or two it would fire up drive fine for a few more min and did it again but if I pull over befor it shut down on me and put it in park it continued like it was gonna stalk out and the rom would jump from nothing to 1 any ideas or thoughts thanks
Gypsychild is offline
Old 07-20-2015, 05:13 PM
Carolina Man
Carolina Man's Avatar
Welcome
Carolina Man is offline
Old 07-21-2015, 12:10 PM
Brandonfilipponi@yahoo.com
Brandonfilipponi@yahoo.com's Avatar
Something could be clogged lines filter injectors etc
Brandonfilipponi@yahoo.com is offline
Old 07-21-2015, 12:15 PM
Gypsychild
Gypsychild's Avatar
Not sure how to check that but I will look into that problem thanks
Old 07-21-2015, 12:18 PM
Also make sure your coils or plugs are ok, gapped correctly, could cause timing probs
Old 07-22-2015, 10:50 AM
The Old Man
The Old Man's Avatar
Does an 01 have a charcoal canister purge solenoid?
Do you have trouble filling the gas tank? Like does the pump click off and not let you fill it?
The Old Man is offline
Old 07-22-2015, 10:58 AM
Gypsychild
Gypsychild's Avatar
No I don't have any problems with pumping gas only when I fill fill it it will leak a little bit that is due to bad flow tube and gasket
Old 07-22-2015, 01:18 PM
Soldier GT
Soldier GT's Avatar
Welcome!
Soldier GT is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
chain
08-17-2015 08:52 AM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 01 mustang Gt please help
