Go Back   MustangForums.com > Vendors & Sponsors > Obsessive Detail
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-22-2009, 01:21 AM   #1
StriderTacticaL
Vehicle: '04 Mustang GT
Default Need help chosing pad
So basically my left borla stinger tip is really discolored and I have tried everything and I realized the only way it would come off is to use a rotary. I used a dremel with a small polishing pad and worked in some borla exhaust cleaner and that did the trick but obviously it wasn't big enough to do the entire tip.
I have a friend who works for a hardware store and can rent out a rotary took for me so I need a good pad I can use to tackle my discoloration problem. The rotary has a velcro surface so I need a velcro pad.
Basically I'm thinking I need the most aggressive pad (since it's all for car paint i'm sure the most aggressive one won't be too aggressive for an exhaust tip) that also doesn't absorb too much polish.
What do you suggest?
Thanks!,
Brandon
__________________
04 GT
K&N FIPK, Accufab 75mm TB & Trickflow plenum, Bassani SS catted X, Borla Stingers, 31 spline T-Lok w/Moser axles, FRPP 4.10's, Hurst billet/plus, MM XD LCA's, MM XL FLSFC, Cobra brakes, Sniper tuned.
StriderTacticaL is offline   Reply With Quote
Old 04-22-2009, 12:27 PM   #2
Juztang
Send a message via AIM to Juztang
I would go with the Lake Country Purple Foamed pad. I use this on metal when it is really bad. It has more cut than foam pads and finishes off nicely.
__________________
http://www.obsessivedetail.com Your source for high quality detailing products and accessories.
2004 Saleen S/C #170
Juztang is offline   Reply With Quote
Old 04-22-2009, 02:03 PM   #3
StriderTacticaL
Thanks,
Where can I get best get them? I don't see it on your site. Oh and since I am ordering a pad, I am soon gonna be glazing and waxing my car and I was thinking about using the rotary to apply the glaze. Do you think this will be safe? I've heard many horror stories of rotaries but I figured if I set it to the lowest setting and just constantly move it around to just spread the glaze, it should be ok?
What pad do you recommend for that?
Thanks,
Brandon
__________________
04 GT
Old 04-22-2009, 04:28 PM   #4
Juztang
I do have the Lake Country foam pads on the site. They are at the bottom of the buffer page and Lake Country page.
You can use the rotary to apply the glaze, just keep it at very low rpms. I would use the gray finishing pad to apply the glaze.
__________________
Old 04-22-2009, 05:53 PM   #5
StriderTacticaL
Hmm....I see the gray finishing pad but a purple foamed wool pad but I thought that wool would be too soft for exhaust tips? I need the most abrasive pad
__________________
04 GT
Old 04-22-2009, 06:04 PM   #6
Juztang
Quote:
Wool cuts a lot better than foam. It is actually more aggressive.
__________________
cobras, pads, purple
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
