Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
nitrous plugs
Old 03-13-2007, 05:39 AM
Quicktime_GT
Quicktime_GT's Avatar
Default nitrous plugs
Got this from BowlingGreenMustangs.com:
aka: Mr. A-Hole
Group: Admin
This should help..........
5.0
Stock E7 heads:
AUTOLITE
stock--stock 25 (5) [14m, .460 Reach, 5/8" Hex]
1 step colder--24 (4) [14m, .460 Reach, 5/8" Hex]
2 step colder--23 (3) [14m, .460 Reach, 5/8" Hex]
-----AR133 (3) [*recessed tip, racing plug]
-----AR132 (2) [*recessed tip, racing plug]
-----AR131 (1) [*recessed tip, racing plug]
NGK
stock--(UR45) 6945 (Heat Range - 4) [14m, .460 Reach, 5/8" Hex]
1 step colder--(UR55) 2248 (5) [14m, .460 Reach, 5/8" Hex]
2 step colder--(UR6) 7773 (6) [14m, .460 Reach, 5/8" Hex]
-----(R5673-8) 3249 (8) [*recessed tip, racing plug]
-----(R5673-9) 3442 (9) [*recessed tip, racing plug]
-----(R5673-10) 4050 (10) [*recessed tip, racing plug]
GT40 Heads:
AUTOLITE
stock--765 (Heat Range - 5) [14mm, .708 Reach, 5/8" Hex]
1 step colder--764 (4) or 104 (4) [14mm, .708 Reach, 5/8" Hex]**
2 step colder--103 (3) [14mm, .708 Reach, 5/8" Hex]**
-----AR473 (3) [*recessed tip, racing plug]
-----AR472 (2) [*recessed tip, racing plug]
**The difference between the 764 plug and the 104/103 plug is the thread. The 764 plug is a half thread whereas the 104/103 plug is a full thread. The full thread plugs are duplicates of the half thread plugs in every other aspect, they both protrude the same amount into the combustion chamber.
NGK
stock--(TR4) 3754 (Heat Range - 4) [14mm, .708 Reach, 5/8" Hex]
1 step colder--(TR55) 3951 (5) [14mm, .708 Reach, 5/8" Hex]
2 step colder--(TR6) 4177 (6) [14mm, .708 Reach, 5/8" Hex]
-----(B8EFS) 1049 (8) [*recessed tip, racing plug]
-----(B9EFS) 1085 (9) [*recessed tip, racing plug]
TFS, Edelbrock, and AFR Heads:
[14mm, 3/4" Reach, 5/8" Hex, gasket seat]
AUTOLITE
1 step colder--3924 (4) [*recommended starting point]
2 step colder--3923 (3)
-----AR3933 (3) [*recessed tip, racing plug]
-----AR3932 (2) [*recessed tip, racing plug]
-----AR3931 (1) [*recessed tip, racing plug]
NGK
1 step colder--(FR5) 3686 (5) [*recommended starting point]
2 step colder--(BKR6EY) 3696 (6)
-----(R5671A-8) 4554 (8) [*recessed tip, racing plug]
-----(R5671A-9) 5238 (9) [*recessed tip, racing plug]
-----(R5671A-10) 5820 (10) [*recessed tip, racing plug]
MOTORCRAFT
1 step colder--AWSF22C
2 step colder--AWSF32C
4.6 2V Bitches
MOTORCRAFT
stock--AWSF-32C (copper)
1 step colder--AWSF-22C (copper)
2 step colder--AWSFA-12C (copper)
AGSF-32C--FRPP heads
NGK
stock--TR-55/ 3951
1 step colder--TR-6 4177
1 step colder--NGK TR6
1 step colder--NGK BR6EF (Non-projected, resistor, v-groove copper)
2 step colder--NGK BR7EF (Non-projected, resistor, v-groove copper)
2 step colder--BP7EFS [PN - 3526] BR7EF [PN - 3346]
2.5 step colder--R5724-8 [PN - 7317]
3 step colder--R5724-9 [PN - 7891]
4 step colder--R5724-10 [PN - 7993]
AUTOLITE
stock--764
1 step colder--103
2 step colder--AR94
3 step colder--AR93
4 step colder--AR92
CHAMPION
YS-59C
DENSO
stock--IT16
1 step colder--IT20
2 step colder--IT22
3 step colder--IT24
Quicktime_GT is offline
Old 03-15-2007, 04:44 PM
Quicktime_GT
Default RE: nitrous plugs
Old 03-17-2007, 09:35 PM
Quicktime_GT
hmm
Old 03-21-2007, 12:49 AM
cobrakiller306
cobrakiller306's Avatar
I plan on running a 150 shot on a 306, should i run 2 steps colder and which plugs do u guys like? i have tf heads as well.
cobrakiller306 is offline
Old 03-21-2007, 01:54 AM
ZW99GT
ZW99GT's Avatar
I went with the NGK TR-6.
ZW99GT is offline
Old 04-03-2007, 04:42 AM
Quicktime_GT
I like ngk
Old 04-04-2007, 05:51 AM
94IVGT
94IVGT's Avatar
can we make this a sticky
94IVGT is offline
BOB ROME
07-26-2023 01:54 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
lmurf60
09-24-2015 10:07 PM
Quick Reply: nitrous plugs
