Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Safe Shot for ford racing mot
Old 09-22-2003, 09:56 PM
  #21
makarovboy
makarovboy's Avatar
Default Safe Shot for ford racing mot
Why yes T5, I was talking about you. I don't know s**t about nitrous, but the hypereutectic pistons in the 5.0 mustang started in '93. Earlier had forged. If you're talking about the ford racing 347, again hypereutectic pistons w/valve reliefs, and also a cast crank.
makarovboy is offline
Old 09-22-2003, 10:16 PM
  #22
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
"fight" "fight" "fight"</P>
...na fighting is bad</P>
...no really its so dumb</P>
...ok yea whatever, lets see some blood!</P>
</P>
mdvaldosta is offline
Old 09-23-2003, 12:56 AM
  #23
vfast
I ♥ Acer
vfast's Avatar
naw we don't need it
vfast is offline
Old 09-26-2003, 12:37 PM
  #24
408Beast
408Beast's Avatar
i had 200 shot on stock ford 302 with forged pistons, and a b303 ( i think it was "B") been a long time ago, i cant remember for sure, , , , just remember to retard the timing 2 degrees for every 50 hp oh nitrous or if you have good ignition (msd, accell, holley) you can go 1 degree for every 50 hp of nitrous.</P>
408Beast is offline
Old 09-28-2003, 07:12 PM
  #25
T5superduty
T5superduty's Avatar
No its not forged pistons. I wish it was. I'm not sure what year blocks they use for the Ford Racing Gt40 long block. But they are hyperutectic pistons I think it. cause it says 9.0:1 compression and if i remember correctly that is using the hyperutectic pistons. I will change all that out after I either blow the motor or after a long time of driving. I was only curious of what it could handle and if it was a good idea to run nitrous or not. thanks for the helpthough. And does anyone have any idea why ford racing would tell me to advance the cam 4 degrees ? They said before I fire it be sure to advance it 4 degrees. I wonder why ?
T5superduty is offline
Old 09-28-2003, 10:28 PM
  #26
makarovboy
makarovboy's Avatar
Hey t5, the cam, with the comination of timing gears they used, if installed straight up, may already be 4* retarded. I can't think of any other reason, as 4* is a lot of advance. Low end would be fantastic, but I would think that the high rpm range would get killed. From what I've heard, most cam grinders would tell you to buy another cam if it has to be advanced 4*. <edited><editID>makarovboy</editID><editDate>37892.8991666667</editDate></edited>
Old 09-29-2003, 04:39 PM
  #27
T5superduty
Hmm. . ya my machanic really wonderd why they wanted theb-303 cam advanced 4 degrees for even more performance. Mabye that it what they did to get 370 horsepower @6000 rpm and 358 lb-ft @ 4100
Old 09-29-2003, 09:37 PM
  #28
makarovboy
makarovboy's Avatar
Yep, could be it's just for that particular build, but I would ask them why just to be on the safe side.
Old 10-03-2003, 11:40 PM
  #29
68stAng
68stAng's Avatar
well the best way that i have heard is to take your total hp and what ever half of that is a safe shot . so if you hav 400 horse power you are safe with a 200 shot of juice. or thats what i have heard from the techs at power house
68stAng is offline
Old 10-06-2003, 11:06 PM
  #30
95Stealth302
95Stealth302's Avatar
T5, you bitch and moan a lot in general, not everything is the end of the world, calm down
95Stealth302 is offline
Quick Reply: Safe Shot for ford racing mot
