what else will i need for my vortech kit?
so im trying to piece together an intercooled vortech kit. i dont know if i have everything down that im going to need, so far all i can think that im going to need is:
head unit(found one rebuilt by vortech locally)
Vortech Bracket Assembly
Vortech Air Intake Assembly
Vortech Oil Feed Assembly
Vortech Oil Drain Assembly
intercooler with piping
vortech bypass valve
injectors
fuel pump
is there anything im missing for this kit to be complete? i know the $1500 96-04GT Supercharger kit "how its done" says to get the discharge assembly with it but since im going intercooled will i need it, no right?
injectors
fuel pump
and im from Placentia. right next to Fullerton and Anaheim.
On a simple setup like a non intercooled kit with stock pulley, everything else stock, some tuners will be able to tune the car with the stock maf. But the stock maf is not easy to tune with. One because it is calibrated for 19lb injectors and will need alot of adjustment to work with 42lb. Another reason is because most GT maf meter have an internal IAT sensor that is built into the maf. With a boosted car you want to have the IAT sensor in the boost pipe. Most tuners will just go ahead and tell you that you need a 90mm Lightning maf. They come already calibrated to run with 42lb injectors and do not have an internal IAT sensor. That way it is easier to setup the tune and hook up an external IAT sensor. The lightning maf that I was using was maxed out at 400whp on my car at only 5400rpm. With an intercooler, powerpipe, and smaller pulley, you will likely be making around the same numbers as my car was. I needed that and a Diablosport Mafia to get a full tune. But it was worth it once my car put down 430whp...
I know it pegged with my vortech setup. Im not sure of the differences a kenne bell would make but just the addition of the new maf and injectors isnt going to give you much more power, just more headroom for air/fuel. I think you will be fine until you start adding more mods.
jwog666
12-27-2021 08:09 PM
