nitrous switches
nitrous switches
getting my nitrous stuff all worked out time to order some switches
i want WOT switch and window switch along with activation switch to turn the system off.
thing is idk what to look for when looking for these switches some are 45 other cost over 100 just for the WOT switch. what gives? anything to look for for amps or anything?
what about a switch that acts as wot and window switch?
thanks for the help?
i am running a N.O.S. window switch/wide open throttle switch. its all drive by wire you can set it to come on and off. instead of having a wide open throttle it runs of the tps so no having to mount a switch on throttle body. and will also run 2 stages and a shift light. was about $140 at summit
