Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
What else do I need with a pro
Old 12-04-2003, 10:31 PM
biggcea
biggcea's Avatar
Default What else do I need with a pro
I am getting the ati procharger and I am wondering what else I should get for my car or what would be good for it. I have an 03 GT with full exhaust already. Should I get a bigger throttle body? Maybe a bigger MAF? Im new to Mustangs and I am trying to get as much out of this car and still be streetable as I can. Thanks for any input.
biggcea is offline
Old 12-05-2003, 02:41 PM
vfast
I ♥ Acer
vfast's Avatar
in this order
1. boost gauge/fuel pressure gauge
2. pop off valve
3. better igintion/ with rev limter
4. at least a t-rex pump 75lph
5. bigger maf
6. FMU or bigger injectors
7. pms for the best engine controls for tuning
8. good plugs/never use boush plat
9. really good plug wires
10. drag radials (a must)
11. fuel regulator (kirban) <edited><editID>vfast</editID><editDate>37960.5289351852</editDate></edited>
vfast is offline
Old 12-05-2003, 04:28 PM
biggcea
biggcea's Avatar
Im getting the kit from ATI so most of the fuel stuff is included but I need to know good brands to look for. Thanks for the reply
biggcea is offline
Old 12-05-2003, 04:56 PM
Cdprowl
Cdprowl's Avatar
You need a bigger throttle bodie BBK makes good ones. Putting all that air in the engine you will need a way to fit it in there the way you like. Maybe a Borla Exhaust bigger exhaust you will need a way to spit all that air out. You will need MAF for sure to replace your stocks will not handle the intake as well as one made for more air flow. New fuel pump all that air will go to waiste if it is not getting the fuel it needs to ignite the cylinders. Port and polish your headers and exhaust. Or you can create a smaller crank with the cams. and a Tornado bolt on it spins the air as it comes out of the air filter and it releases it into the ATI procharger and then the procharger will release it into the engine. basically anything that haves to do with your air intake and outake is what I would upgrade. THink about it you are wanting to put more compressed air...what 11psi? into an engine your going to need more of a spacial input like a bigger throttle body for it to get the effect you want and the more air you put in there the more air you are going to have to release out through the exhaust so a bigger exhaust. </P>
Oops almost forgot your going to need more gauges. Not just for your increased MPH but to monitor your psi in your charger and your shifting and blah blah blah... and yeah the spark plugs boush double plat and the other things vfast said. <IMG src=smileys/smiley1.gif border="0"></P>
Oh and on your ignition try and get MSD Programmable DIgitial -7 it comes with laptop software you can plug into and modify also and its got BOOST CURVE hehe</P><edited><editID>Cdprowl</editID><editDate>37960.755787037</editDate></edited>
Cdprowl is offline
JoshyGT
09-19-2017 08:52 PM
mapitts
05-11-2016 10:14 AM
jerrytubes
10-23-2015 12:11 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
EASTIDEE123
09-15-2015 11:08 AM
Quick Reply: What else do I need with a pro
