Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
question on cam selection with boost , please help
Old 02-01-2013, 11:02 PM
bossmustang1025
bossmustang1025's Avatar
Default question on cam selection with boost , please help
I have a 07 boss mustang and I have majority of the bolt ons installed now.. I plan on next summer on buying the hellion turbo kit but I want to install cams before I do that.. does it matter on what type of cams I buy with or without I boost? I plan on pushing like 11-12 lbs .. I'm looking into Ford motorsports hot rod cams or Ford racing mother thumper cams .. what would u suggest on cam selection? Also does anyone know if the hellion turbo kit comes with turbo exhaust manifolds ? I want to buy long tubes but I don't know if that would work with the turbo kit I plan on buying .. thanks for the help !!!
bossmustang1025 is offline
Old 02-02-2013, 11:04 PM
BLWN PNY
BLWN PNY's Avatar
I want the Hotrod cams too, I talked to my tuner and have seen a few people with the Ford Hot Rod cams with turbos and they work ok.
peak gains will be with a blower cam though. but I just love that idle with the hot rods
The hellion kit comes with a reverse Y to get back to the turbo. you can use long tubes you may just need a lil pipe tweeking
to give you a look at how its set up
BLWN PNY is offline
Old 02-04-2013, 07:42 AM
97stanger
97stanger's Avatar
your best bet is custom grind. Same price and exactly what you should be running. Call Bullet Racing and they will hook you up. Also if considering going turbo, dont waste your money on long tubes...
97stanger is offline
Old 02-05-2013, 07:21 AM
bossmustang1025
Ok thanks guys I appreciate it, I think what I'm gonna do is just buy the hot rod cams and put long tubes on it for this summer and determine the rest when the time comes,because we all know money is tight now a days .. now that being said what size injectors should I get? I'll problky get the bbk fuel rails to and plugs and wires . I already put 3;55 gears in,spec aluminum flywheel , bbk throttle body,sct livewire tuner, and it came with full coil over suspension and manifold back saleen exhaust ,and ram air intake .. if you have any other ideas please let me know I'm trying to get ready before the drag strip opens up ..
Tivo304
08-28-2023 12:19 PM
carid
07-08-2016 09:55 AM
Daddys Girls GTs
09-14-2015 08:46 PM
EASTIDEE123
09-14-2015 03:52 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: question on cam selection with boost , please help
