2005-2010 Mustang V6 Power Stop Brake Kit - Rotors & Pads?
This set seems too good to be true,and here is why:
2005-2010 Mustang V6 Power Stop Brake Kit - Rotors & Pads (Front & Rear Kit)
This performance mustang brake kit from Stage 3 Motorsports includes power stop brake drilled and slotted brake rotors and power stop ceramic brake pads.
This is everything you will need to upgrade your 2005-2010 mustang V6's stock brakes. Fits V6 only.
These powerstop rotors are stock sizes, so your stock calipers will work perfectly.
This kit usually ships out from our warehouse in: 24 Hours
and the Price is $369.95, does anyone know anything about this brand and If the vendor is viable.
Thank you for reading this.
Why do you think your brakes need "Upgrading"? Are they fading after repeated hard stops?
Drilled rotors are not a good idea and offer no real benefit other than appearance and if used hard will crack.
Upgrading the pads only is the best single way to improve braking and then the next best way is to improve your tires.
09-16-2015 07:53 PM
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
