Brake pads for road course
Old 02-05-2011, 07:38 PM
Argonaut
Argonaut's Avatar
HPS and HP+ are not track pads. They are high end street pads that can survive some light track duty - at least HP+ can. DTC60, 70, HT-10 and a few others are Hawk's track pads. This is a 3600 lbs car capable of hitting roughly 130 on most tracks with a decent straight - that is a whole lot of vehicle to slow down. IMO HP+ is the minimum and I'd only recommend them for a newer HPDE driver on street tires.
Argonaut is offline
Old 02-05-2011, 09:44 PM
Ansibe
Ansibe's Avatar
Argonaut, you're right, DT60 is Hawk's track pad. My bad.
What does "minimum" mean to you? Do you think the stock pads will fade to the point of failure? A 14" disc and brembo caliper have a lot of heat capacity, and dot 4 fluid boils at a very high temp. With fresh fluid and proper bleeding I think the GT brembo setup is a good start for most track day guys. But you need to be sensitive, if you feel the brake pedal soften you have to have the sense to back off.
I'm an old fart, well past my prime, and I don't go 10/10ths any more. I still end up quicker than 90% of the people at the track, in an unmodified car. And it doesn't matter. If the slowest guy out there has more fun than me, he wins.
Ansibe is offline
Old 02-06-2011, 08:37 AM
nemosgt
nemosgt's Avatar
Well said.
Cheers.
nemosgt is offline
Old 02-06-2011, 10:03 AM
joenmina1
joenmina1's Avatar
Never forget about transfer material when switching pads. Transfer occurs when hot pads "transfer" pad material to the disc. A well functioning brake system uses this transfer layer to develop a high coefficient of friction. Good transfer not only helps braking, it will help your discs last longer. Google "brake pad transfer" for loads more about this. Stop tech has a great explanation here: http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Dedicated metallic track pads are so abrasive when cold (i.e., on the street) that they clean off any previous transfer material. If you run track pads for long on the street, they will eat through the disc and quickly destroy it.
I learned this the hard way when I switched my BMW M from stock pads to cool carbons for track use. The cool carbon transfer to the stock disc was uneven and the resulting vibration made the car un-driveable on the track. I ended up buying new Performance Friction discs and pads at a cost of $2k. I was not happy. I probably should have bought something like the Hawk HPS plus to clean them off, and then used them for track days. But I was too stupid.
A smart man learns from his mistakes. A really smart man learns from the mistakes of others. Here's your chance to learn from my mistake.
Thank you both for your insight and guidance. I heard that the track pads can really mess up your rotors and it is a good idea to have dedicated track rotors and pads. Thats why I went with the high end street/track (as Hawk classifies it) HPS instead of the HP +. What are your thoughts? I have a week before my HPDE 1 event.
Again, thanks for sharing your knowledge with a track noob
joenmina1 is offline
Old 02-06-2011, 04:13 PM
Argonaut
Argonaut's Avatar
With one week left, its unlikely you have time to do anything, unless you have a performance shop nearby that stocks track pads. If you did have the time, my recommendation would be to buy a set of HT-10 for the front and HP+ for the rear (or HT-10 on rear would work also). The HT-10 is one of those pads which doesn't care much about previous transfer layer. It is abrasive and with a good bedding will scrape old material off (in fact if you bed them at night you can see sparks fly, its kind-of cool). Its a good pad to swap between street and track. So, just put them on a day or two before an event and bed them in with some good hard stops from speed. Then just drive them to the track and swap back to the street pad afterwards. Dont' worry about your rotors. Its true that track pads are abrasive, especially when cold (below their operating temp range), but if you go to many track events you will crack your rotors long before they wear thin. One good hard day on the track will cause spider cracks. Each subsequent day will spread the cracks until they crack clean thru. Typically, an intermediate to advanced driver will only get 5-8 days out of a set of OE quality rotors (some less, some more) before throwing them away.
Assuming you don't have time to buy a set, sounds like you will going to a DE with the HPS. So be it. They will work and you may not fade them at all - it really depends on you. I know a guy who drives a C6 Vette and is pretty quick. One day at Summit Point he completely used up his track pads - so he swapped in his street pads and went out for the afternoon sessions. He said it wasn't good but the car still stopped and he was still fast, he just took it down a couple notches.
What about your brake fluid? You need DOT 4 fluid for track work. Stock fluid is DOT 3, it has a lower boiling point. You need DOT 4 fluid to survive the high temps seen on the track. Here again you may or may not have problems depending on how fast you are going and how hard you need to brake for turn-in. If you start feeling a mushy pedal its probably your brake fluid boiling.
Argonaut is offline
Old 02-09-2011, 09:14 AM
leahyz
leahyz's Avatar
Default Porterfield R4's?
I was curious if anyone had run the Porterfield R4's. I run these on my previous track car, a gutted and modded 1993 SHO (250hp, 3000lbs, on RA1s). I would drive them to and from the track as well (Usually Gingerman). They squeal when cold, but I love the performance when it's hot. With a 13" front rotor and dual piston calipers up front I could late brake everyone.
I got an 07 GT last fall and plan to do some HPDE events with it and have been contemplating pads. I know HP10's are generally the standard I see discussed, but I've been very pleased with my R4's to date. I've not had the new car to the track... yet.
leahyz is offline
Old 06-13-2011, 09:26 PM
GrabberStang11
GrabberStang11's Avatar
Did you end up going with the Hawk Pads? I'm starting to get into HPDE events myself and I was planning on getting those, but I wanted to know what your experience was like.
GrabberStang11 is offline
Old 06-14-2011, 06:24 AM
Norm Peterson
Norm Peterson's Avatar
OP has been MIA for a couple of months. Try sending him a PM.
What I can tell you is that his timed laps out on the big track were consistent at about mid-pack (which may or may not have been enough to work the brakes hard with the weather being relatively cool), and that he put down some very impressive runs on the autocross course (which wasn't at all hard on the brakes except for getting slowed down after crossing the finish). RTTS Results
Norm
Norm Peterson is offline
Old 06-14-2011, 09:06 AM
joenmina1
joenmina1's Avatar
Hi GS11, I did use the HPS at Infineon back in February and they worked flawlessly. Infineon is a rather twisty course with only 3 straights (2 short, 1 long) so lots of quick accelerations and full braking. The pads had a lots of material remaining for my next track day next month.
Here are a couple of pics:
Old 06-15-2011, 08:10 AM
GrabberStang11
Thanks for getting back to me. Nice car by the way. I think I will go with the HPs after all
Matt's 95 Stang
10-05-2015 07:16 AM
folivier
10-02-2015 05:34 AM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Brake pads for road course
