S197 Shelby Section This section is for technical discussions pertaining specifically to the latest installment of the Shelby Mustangs; the Shelby GT, the CS6, and the awesome GT500.
Help me build a solid 10 second car
Old 08-29-2010, 06:31 AM
stock
stock's Avatar
Smile Help me build a solid 10 second car
I have an 08 GT-500 with only the FRPP cai and tune, CHE relocation brackets out back with stock control arms, and a Pypes axle back exhaust. It hasn't been Dyno'd or raced yet (previous post asked for HP quesses). I want to build the car until it SHOULD be around the high ten's and then race it. Here's what i think will do it:
Suspension first:
CHE adj panhard bar (should i also get the panhard brace?)
CHE adj upper and lower control arms
Eibach lowering springs (Pro kit or Sportline?)
Tonika struts and shocks?
Nitto NT05 drag radial rear tires
Then,
Ford Racing short shifter
Ford Racing rear gears (3.73)
Then,
Whipple supercharger (size?),injectors (size?), plugs (anything else?), Throttle body, and of course a good tune.
The goal is to keep the GT-500 as streetable as possible but make it a beast in the quarter mile. It would not be raced often.
Any other mod's needed? Am i on target? Recommendations on anything experienced welcomed to help me acheive my goal.
stock is offline
Old 08-29-2010, 09:57 AM
Lifter583
Lifter583's Avatar
Honestly a stock Eaton blower pulley change to a 2.6...a great tune...some work to keep the intake temps below 130 degrees so the car wont pull timing...a little suspension work with an aluminum ds.. with good tires..you are there...
Lifter583 is offline
Old 09-01-2010, 06:29 AM
mobydick
mobydick's Avatar
It takes a little more then that, about 600 at the wheels. 2.6 upper, 10% lower, Long tubes, CAI, good tune for C12/14/16 Alu/CF DS. 373 gears, DRs Ported eaton, lot's of cool dry air. Then he will be luck to put a 10s down every time.
mobydick is offline
Old 09-01-2010, 06:43 AM
Lifter583
Lifter583's Avatar
What RWHP do you have with your mods?? I agree air density will be the big factor...but some guys do break 10s with 550 and a little over..but to be in deep..better go to the 725 Whipple setup...
Old 09-02-2010, 09:07 AM
stock
stock's Avatar
Thanks for the input. I should be putting down around 480-490 at the wheels with cool temps. What do you guys think about modding these babies up and hurting the resale value? I'm thinking oh well, but i reckon it's something to at least consider.
stock is offline
Old 09-02-2010, 10:32 AM
zporta
zporta's Avatar
i wouldnt worry about resale value... and if u are just keep all of your stock parts.
zporta is offline
Old 09-02-2010, 05:20 PM
mobydick
mobydick's Avatar
I have the older version of the Evolution stage 4, Not Whipple TB or Lower. Mine makes 561 hp and about the same Tq. Mine a vert so it's alittle heavier. My best is 11.491@123.33.
mobydick is offline
Old 09-02-2010, 05:57 PM
Lifter583
Lifter583's Avatar
Strong car...I bet you are closer to breaking the 10s then you think...with the right tires and all the right moves...
Old 09-13-2010, 08:52 AM
Cal26Stang
Cal26Stang's Avatar
sounds like you have some traction issues
Cal26Stang is offline
Old 09-14-2010, 09:49 PM
stock
stock's Avatar
Those are some good numbers. I am doing a Dyno in two weeks with just the FRPP and Procal tune. I'll be interested to see what happens. For the rear end i ended up ordering Steeda adjustable upper arm and mount, billet lower arms, (i already have the relocation brackets), and an adjustable panhard bar with brace. Then i'll go ahead with the short throw and 3:73's and see what i can do before i start the power mod's. Think i'll have any pinion issues? I heard it should be set between zero and negative 2?
stock is offline
Urambo Tauro
Oil and Oil Related Topics
12-11-2017 07:16 AM
ohfarrell
10-18-2015 11:27 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
PearlGenPu
08-12-2015 01:57 PM
Quick Reply: Help me build a solid 10 second car
