lowering and 20 inch ,wheel/tire size question
20's
Here is what I did with my 2011.
20 x 10.5 and 20 x 9.5
No rubbing etc.
Tires have less than 200 miles on them and I'm selling the wheel/tire combination. Going back to stock and trading the car in on a 2013.
Let me know if you want to save some money.
I have about $3,500 invested in the wheels/tires.
No rubbing etc.
No rubbing etc.
No rubbing etc.
2) What wheels, offsets?
3) What tires? brand and size
Vossen Wheels
Sure, here is a link to pictures of the car with the Vossen Wheels, Nitto Invo tires and all the specs. You can also click on the header at the top and go back to a menu to view the other mods that I've performed on the car.
Link: http://marblesmotors.com/2011%20GT500%20Menu.htm
Did you have to use hub rings? I assume the vossens didn't come with the factory hub bore of 70.6??
We have very similar cars (11 GT500 vert sterling grey/Black stripes).
My friend runs 18x11's with either 305x40 or 315x40 without any rubbing at all. Pretty sure its the 315x40's
Well that all depends on HOW you are going to lower the car and What suspension setup you go with and what rims. If you want to see a extremely well done setup check out Griggs racing http://www.griggsracing.com/product_...roducts_id=607
With their setup you can run 305/35/18 front
315/30/18 Rear no problem
I for one do not see the reason to go with 20s (other then the looks) if a 18 or 19 rim fits the brakes you have the only reason to go with large rims is to fit a larger rotor for better breaking. A larger rim and tire means more weight.
I also think it is crazy that shelby has not already outfitting the GT500 with a suspension and wheel setup that allows for much larger tires then it does. especially the newest with over 900hp that is crazy HP to try to handle on such narrow rubber. Look at the tires on a ZR1, Vipper or even a FordGT or any other car that has over 500 hp and they all have at least 315s on the rear.
The fact that a GT500 buyer has to go out and buy new rims and tires is crazy the GT500 should come with as big a tire out back as possible to get that power to the road.
Diode Dynamics
28
05-26-2022 12:02 PM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
11-09-2016 11:44 AM
NorthAmericanTuning
03-18-2016 11:21 AM
mustangsrforever!!!
08-06-2015 12:04 PM
