S197 Shelby Section This section is for technical discussions pertaining specifically to the latest installment of the Shelby Mustangs; the Shelby GT, the CS6, and the awesome GT500.
DivisionX GT500 Fuel Rails and Fuel Rail Kits IN STOCK
Old 06-11-2012, 07:45 PM
Boostaddict
Former Sponsor
Boostaddict's Avatar
Default DivisionX GT500 Fuel Rails and Fuel Rail Kits IN STOCK
All new from DivisionX are their high flow billet aluminum fuel rails for the 2007-2012 Shelby GT500. The DX rails are made of high grade billet aluminum and CNC machined to perfection. Once machined the rails are sent off to be anodized for a long lasting protective finish. The DX rails use -8an O-ring fittings on each end and have (2) 1/8" NPT ports located on the passenger side rail so you can install electric and mechanical fuel pressure gauges as well as use it for the fuel supply on a wet nitrous setup.
The DivisionX fuel rails fit all 07-12 GT500's using the stock Eaton, TVS, Whipple 2.9L, 3.4L and 4.0L as well as the Kenne Bell 2.8 and 3.6L.
Fuel Rail Features:
-CNC Machined High Grade Billet Aluminum
-Anodized For Long Lasting Protective Finish
-Machined In Mounting Tabs designed to prevent tab failure found with other manufacturers fuel rails
-(2) Built-in 1/8" NPT Ports for electric or mechanical fuel pressure gauges or for fuel supply when using a wet nitrous kit.
-Fits Stock Eaton Supercharger, TVS, Whipple 2.9L, 3.4L, 4.0L, KB 2.8L, 3.6L
-Includes Driver and Passenger Side Fuel Rail
-Billet Aluminum mounting plate for FRPS with Viton O-ring
-Stainless Steel Mounting Hardware Included
NOTE: Due to clearance issues between the fuel rail and supercharger plenum on the 2.9L/3.4L Whipple and 2.8L KB only stock height EV14 injectors can be used. Taller EV6/EV1 height injectors will not fit. Also, due to the location of the EGR valve on the 2.9L access on the passenger side rear fuel rail is limited to a -8an plug only. The only way to use a different fitting there would be to delete the EGR valve.
FUEL RAIL KIT
http://www.lethalperformance.com/201...-rail-kit.html
BLACK RAILS
http://www.lethalperformance.com/201...uel-rails.html
CLEAR RAILS
http://www.lethalperformance.com/201...l-rails-1.html
Boostaddict is offline
drfister
05-03-2018 10:38 PM
bret1197
08-25-2015 05:21 AM
inyadreems
08-21-2015 09:10 AM
Soldier GT
08-12-2015 03:46 PM
StangMuscle
08-12-2015 07:27 AM
Quick Reply: DivisionX GT500 Fuel Rails and Fuel Rail Kits IN STOCK
