Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
1.7rrs on crower 15511
Old 06-10-2008, 09:30 PM
jkrum10238
jkrum10238's Avatar
Default 1.7rrs on crower 15511
i decided to go with this cam, should i stay with 1.6 ratio or step it up to 1.7 the rest of my motors stock except exhaust
jkrum10238 is offline
Old 06-10-2008, 09:41 PM
HACKGT350
HACKGT350's Avatar
Default RE: 1.7rrs on crower 15511
need specs on the cam i cant read your mind. anyway take the lift of the cam and multiply it by 1.6 and it will give you your total valve lift with that rocker arm same goes from the 1.7
HACKGT350 is offline
Old 06-11-2008, 08:41 PM
jkrum10238
jkrum10238's Avatar
Brand:
Crower
ProductLine:
Crower Performance Level 2 Camshafts
PartType:
Camshafts
Part Number:
CRO-15511
CamStyle:
Hydraulic roller tappet
BasicOperatingRPMRange:
2,200-5,500
IntakeDurationat050inchLift:
218
ExhaustDurationat050inchLift:
224
218 int./224 exh.
AdvertisedIntakeDuration:
278
AdvertisedExhaustDuration:
282
AdvertisedDuration:
278 int./282 exh.
IntakeValveLiftwithFactoryRockerArmRatio:
0.468 in.
ExhaustValveLiftwithFactoryRockerArmRatio:
0.486 in.
0.468 int./0.486 exh. lift
LobeSeparation(degrees):
114
IntakeValveLash:
0.000 in.
ExhaustValveLash:
0.000 in.
ComputerControlledCompatible:
No
GrindNumber:
218HR224
Old 06-11-2008, 08:53 PM
HACKGT350
HACKGT350's Avatar
with 1.7 intake valve lift is .5304 and exhaust is .5508
with 1.6 intake valve lift is .4992 and exhaust is .5184
so there are your valve lifts with the different roller rockers find out how much lift your heads are good for and what you want out of your aplication
s15driftking
09-07-2006 12:54 PM
schwindty
03-22-2006 10:09 PM
redstanger
12-22-2005 11:06 PM
StangGt01
04-27-2005 09:21 PM
Crash7772
04-03-2005 12:50 PM
Quick Reply: 1.7rrs on crower 15511
