Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
84 302 manifold swap question
Old 09-19-2010, 11:18 PM
chico
chico's Avatar
Default 84 302 manifold swap question
New to this site and really couldnt find anything out about this. I have an 84 302 with the tbi setup. Would I be able to swap out the tbi setup for the efi setup from a later model (87-91) 302. What would be needed to do this swap?? Not the whole engine block, but just the manifolds. Do they fit the 84 blocks?
chico is offline
Old 09-20-2010, 06:49 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
fuel lines for such, complete wire harness, , ecm, throttle linkage, upper and lower intake, maf set up if you choose such cause 87-88 = SD and 89-93 = maf, you'll also need and ecm and there may be a few things I'm forgetting...............also ability to wire it all up.....
mjr46 is offline
Old 10-18-2010, 12:15 PM
mitch84
mitch84's Avatar
Chico you are trying something that is one of the biggest pain in the rear in all mustanghood. I tried going that ro ut but it costs more than your car might be worth! You can try to find all the stuff you need from a junk yard car, but that's usually the first thing to go. I wonder if the new kits from edlebrock, and holley that convert carbs to fuel injection might be a good choice. I got a fuel regulator, new intake manifold, and stuck a carb on top. Much easier but not easy.
mitch84 is offline
Tivo304
08-28-2023 12:19 PM
97SN95GT
09-13-2015 09:45 PM
v8sn95
09-07-2015 10:17 AM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: 84 302 manifold swap question
