Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
problem with my 84?
Old 06-23-2013, 08:51 PM
DK Pony
DK Pony's Avatar
make sure there are no ports on the carb that are left open. If it has a vac port that is not used make sure it is capped. Some of them won't have vac at idle but as the throttle plates move past certain spots in the venturi they will open.
OK so it sounds like you are saying it has an off idle hesitation.
1st make sure all the vac lines are good.
2nd make sure all ports on the carb have something on them. If it isn't used it has to be capped.
3rd set the carb to a basic startup setting. (does it have an electric choke?) If yes make sure the choke is working properly too
4th fine tune the carb
DK Pony is offline
Old 06-23-2013, 09:07 PM
Noob X
Noob X's Avatar
Thanks a lot man tomorrow I'm going to check the nosel size I watched the holley 600 vid and said that if its missfiring when accelerationg at low rpm to upgrade the nosel
Noob X is offline
Old 06-23-2013, 09:10 PM
Noob X
Noob X's Avatar
Gonna take it apart tomorrow hopefully its that thanks again for the info was breaking my head trying to figure it out
Noob X is offline
Old 06-23-2013, 09:36 PM
DK Pony
DK Pony's Avatar
No prob man. Keep us posted and good luck.
DK Pony is offline
Old 06-23-2013, 09:38 PM
Noob X
Noob X's Avatar
Thanks deffinetly will do
Noob X is offline
Old 06-25-2013, 07:03 PM
Noob X
Noob X's Avatar
Took a look at the carb jet its only a 31 same as the oem carb haven't gotten the chance to adjust the accelerator pump but here's a quick sound clip
Noob X is offline
Old 06-26-2013, 04:46 PM
mongolchuck
mongolchuck's Avatar
I bought the same carb for my 85 and had the same problem. I had to put much smaller jets in (i was at about 5000ft). I also put in a more aggressive accelerator pump cam. It takes time to tune it but its not too bad.
mongolchuck is offline
Old 06-27-2013, 06:35 PM
Noob X
Noob X's Avatar
It had a 31 nosel I went up to a 37 then to a 40 and still the same was a bit better with the 37 but still bad idk what to do anymore lol
Noob X is offline
Old 06-28-2013, 08:46 PM
tinman
tinman's Avatar
Check the fuel level in the float bowls......
Thats usually a good place to start when trouble -shooting a Holley carb......
tinman is offline
Old 06-30-2013, 01:33 PM
Noob X
Noob X's Avatar
It ended up being the egr spacer the bottom gasket had went and it had a leak eliminated all of that crap now she doesn't do it any more
Noob X is offline
Seanam
10-04-2015 10:15 AM
mdj89
09-23-2015 08:49 AM
kachuy10
09-22-2015 01:27 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: problem with my 84?
