Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
possible map sensor issue?
Old 07-14-2015, 08:12 PM
86 newbie
86 newbie's Avatar
Default possible map sensor issue?
Ok so i have a 86 5.0 i just got done putting ported e7 heads on, a cobra upper and lower intake, and an x-303 cam in it. When the map vacuum line is on the idle shoots way up to about 2500 but doesnt miss or anything. When i take the vacuum line off it idles back down but starts running rich and misses bad. Is there anyway to fix the sensor for the cam? Is there anything i can do? The tps sensor is also on .9, tomorrow i need to make the holes bigger so i can adjust it more closer to .97. The lobe separation angle on the cam also is 112. Thanks for any info.
86 newbie is offline
Old 08-16-2015, 08:26 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
it'll never run right with that cam on speed density.......requires mass air if you don't already have it converted.....if converted no line should be hooked to map...map becomes bap...........check for vac leaks
mjr46 is offline
Old 08-17-2015, 05:59 AM
dawson1112
dawson1112's Avatar
MAF conversion, only way youll get the thing to idle correctly, your not pulling enough vacuum on the map with that cam.
dawson1112 is offline
Old 08-17-2015, 07:30 AM
88 orangepeel notch
88 orangepeel notch's Avatar
And don't touch your TPS, it's fine where it is.
88 orangepeel notch is offline
Jb145700
08-21-2022 06:37 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
yourmom6990
09-14-2015 10:52 PM
TfcCDR
09-14-2015 12:08 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: possible map sensor issue?
