Homemade Coil Spring Spacers
After a couple of weeks with my new suspension, I'm not thrilled with the ride height (slightly low in the rear) or the ride itself. I'd be happy with 1/4"-1/2" more height in the rear. To address this and also potentially help with impact harshness I'm thinking about fabricating some spacers out of rubber stock (like this stuff: http://www.mcmaster.com/#standard-rubber-sheets/=mz7gbs).
Basically, I'd cut the rubber to the right diameter and insert it between the stock upper spring isolator and the body. I figure a 1/2" disc of fairly hard rubber (around 70-80A durometer) should get me around a 1/4" raise and maybe help slightly with impact harshness. I'd use it at the top mount instead of the bottom because there's more sheetmetal around the spring.
Before you ask why I don't just try different springs, I have Steeda Sports, which unless I'm wrong are the mildest available in terms of height and ride quality. Better shocks (I have STR-T's) might help with the ride, but not the height.
Any thoughts or reasons not to do this?
Did you remove the coil spring seats already? If you did, get new ones from ford, They may add just the right amount of height you are looking for. If you still have the old ones, try these instead.
Poly doesn't compress as much as rubber so again, they may give you the smidge of height you are looking for...
http://www.uprproducts.com/mustang-r...isolators.html
And no, I wouldn't use flat Rubber stock as it will simply slip out from under the spring over time.
Just curious, how/why would the disc I'm thinking about slip out? It would be "locked in" on the sides by the sheetmetal and below by the stock isolator.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
