HELP with lowering springs install
So I ordered a set of SR Performance lowering springs form American Muscle and I decided to try the install myself. It's been a nightmare.
I'm using the installation guide found here>>>>> http://www.americanmuscle.com/srperf...t-install.html
I am trying to remove the strut rod nut (Step 11 on the tutorial) and the nut and strut rod just keep spinning. The question I have is, do I have to have an impact wrench to get this nut off? Any help would be extremely helpful Thanks.
Impact is almost the only way. You can hold the shaft at the very top with a rag
And vise grips but if the shaft gets marred up it will lead to premature
failure of the strut. I hope you are using spring compressors
