Suspension Ask all of your general suspension questions here!
2008 GT Lowering Thoughts
Old 10-16-2015, 01:45 PM
mwerthman
mwerthman's Avatar
Default 2008 GT Lowering Thoughts
Hi All,
I have a 2008 GT that I was considering the possibility of lowering it about an inch, max.
The car only has 21K miles. Is there anything other than the new springs that I need to do?
I have had several opinions thrown my way.
Thank you.
mwerthman is offline
Old 12-30-2015, 09:03 PM
vintageaion
vintageaion's Avatar
Caster bolts/plate to allow you to align the front wheels better.
Panhard bar to align the rear after you lower it.
Try Ford Racing Springs.
Gap will look similarly to this:
vintageaion is offline
Old 12-30-2015, 09:09 PM
Simon1
Simon1's Avatar
You will need the following:
Springs
Shocks/struts
Adjustable panhard bar
Alignment
Possibly camber bolts
If you only do springs your rear end will be off center ached the socks will wear out really fast.
Good luck.
Simon1 is offline
Old 01-02-2016, 07:11 PM
tj@steeda's Avatar
Yes, not as easy as just adding the springs as the rest of the suspension is affected.
At the very least, you will need a panhard bar then followed by the shocks & struts and the CC plates.
Doing the springs & shocks at the same time will save on install labor.
I can provide forum pricing if you email me at tim@steeda.com.
Best Regards,
TJ
tj@steeda is offline
66_grn_fstbk
10-27-2015 10:44 PM
ucinn
10-23-2015 06:55 AM
fcarpio
10-19-2015 04:29 PM
66_grn_fstbk
10-13-2015 12:57 PM
alan0614
Carolina Regional Chapter
10-10-2015 07:30 PM
Quick Reply: 2008 GT Lowering Thoughts
