Suspension Ask all of your general suspension questions here!
Front end shimmy and noise...
Old 12-29-2014, 08:21 PM
dvn4life
dvn4life's Avatar
Default Front end shimmy and noise...
Hey everyone. Have a 2014 GT. About a month ago I slammed the front right wheel into a curb (in a sharp left turn), going slow at ~ 3mph. It hit hard enough to pop the retainer clips on the front lower panel (idk the technical name), without breaking anything.
Anyhow...ever since it has a front end shimmy at about 40mph and above. Not hard core, but slight.
I took it to get it aligned. That reduced the shimmy slightly. After looking underneath, I don't see any visible damage (i.e. anything bent, etc).
Ideas? The curb ground off a 2 inch long piece of the wheel lip...could that cause the slight shimmy?
TIA
Pat
dvn4life is offline
Old 12-30-2014, 07:53 AM
BabyGT
BabyGT's Avatar
Sounds like you need to get wheel balanced, that's a decent chunk to have lost from the rim, sounds like its out of balance now. Same effect as knocking off a wheel weight.
BabyGT is offline
Old 12-30-2014, 08:24 AM
bigo5552000
bigo5552000's Avatar
You could have bent your wheel. My wife has done that twice just from hitting potholes! It felt like a badly unbalanced wheel.
bigo5552000 is offline
Old 12-31-2014, 06:49 AM
dvn4life
dvn4life's Avatar
Okay thanks. I'll get it checked. The alignment wasn't off much at all.
Pat
dvn4life is offline
Old 01-01-2015, 12:02 PM
dvn4life
dvn4life's Avatar
Wheel is definitely bent. Know someone that has a set of the same wheels...free. Thanks for the input, and happy new.
dvn4life is offline
Old 01-01-2015, 07:15 PM
bigo5552000
There are shops that can repair bent wheels for $100-$150. Depending on how bent the wheel is.
Old 01-08-2015, 04:14 PM
ticopowell
ticopowell's Avatar
With that much of the rim missing I would say balance the wheel and you should be ok. If there wasn't any rim missing I would say that you damaged the bearings... so if the vibration/shimmy doesn't go away then I would get that checked out.
Good luck.
ticopowell is offline
zsmart
Convertible Tech
02-29-2016 08:33 AM
the5
09-19-2015 06:13 PM
Sparks_88
09-08-2015 01:06 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: Front end shimmy and noise...
