Suspension Ask all of your general suspension questions here!
Torque setting (replaced front lower control arm)
Old 11-30-2015, 01:59 AM
Jeff Modica
Jeff Modica's Avatar
Default Torque setting (replaced front lower control arm)
I need torque spe"@cs for the Front control arm to the k-mem"ber, nut for ball joint to the spindle, sway bar link with polyurethane bushings (if that makes a difference), reckon Pinion (the two bold in the front (where you would put offset bushings if my car were lowered), outer tie rod. Thank you!!
Jeff Modica is offline
Old 11-30-2015, 10:41 AM
Urambo Tauro
Urambo Tauro's Avatar
I don't think poly bushings affect the torque spec. If they did, a note would be included with the new bushings. Stock specs are as follows:
Front control arm pivot bolts/nuts: 141-191 ft lbs
Balljoint-to-steering knuckle nut: 109-149 ft lbs
Sway bar link nuts: 132-192 IN LBS
Steering rack-to-crossmember bolts: 30-40 ft lbs
Tie-rod end-to-steering knuckle nut: 35-47 ft lbs
Urambo Tauro is offline
Old 11-30-2015, 12:08 PM
Jeff Modica
Thank you
Urambo Tauro
12-01-2015 11:17 AM
Urambo Tauro
12-01-2015 11:16 AM
warpedballer
11-30-2015 08:01 AM
JUSTA2V_04
11-25-2015 05:40 PM
demas
11-23-2015 04:12 PM
Quick Reply: Torque setting (replaced front lower control arm)
