maybe a bad fuel pump? check the fuel pressure. and the fuel filter possibly. mine did the samething, i changed the filter 9 months ago,..... it was the original filter that came with the car.had a ford part number and everything on it. the fuel pump was only throwing out like 20psi. you should be between 32psi and 45psi if i remember correctly.
