SVT Forums
Z-rated Tires vs. W-rated Tires
Old 01-17-2005, 12:35 AM
TBlake
TBlake's Avatar
Default Z-rated Tires vs. W-rated Tires
My '99 Cobra has Michelin Pilot Sport 265/35 ZR18's on the front wheels. I am about to replace them, but there is a big difference in price between Z-rated and W-rated tires. If I get the W-rated (in order to save a couple hundred dollars), will I lose performance? Will I be able to notice the difference? I see that the W-rated tires have a speed rating of like 168mph. That seems plenty..... If the Ws are not recommended, do you guys know a good Z-rated 265/35 ZR18 that doesn't cost a fortune???
TBlake is offline
Old 01-17-2005, 01:58 AM
Birdieman4
Birdieman4's Avatar
Default RE: Z-rated Tires vs. W-rated Tires
The brand and characteristic of the tire will affect it more that just a speed rating. As a general rule, Z rated tires tend to have a lower treadwear rating than W rated tires. What that means is they will be stickier, but not last as long. It all comes down to what you want out of the tire. Do you want a combo rain/dry tire, or do you want an all out performance dry tire? Those pilot sports are pretty good dry tires, although not so much after they have been used up some. They are also ultra expensive brand new. In that size, I recommend a BFG KD or a Bridgestone S02 for all out performance. If you want a dry/wet combo tire, i recommend a Bridgestone S03 or maybe a Perelli P Zero Rosso. For the $, these tires are excellent values, and dominate their class in performance.
Birdieman4 is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
marc954
09-29-2015 11:18 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: Z-rated Tires vs. W-rated Tires
