99 mustang cobra transmission
well im planing on pushing 600+ to the rear wheels i was wondering if a stock t 56 would be able to handle that. and what are the mods needed to make the t 56 fit in my 99 cobra
im sure mfj already told you the answer but it should work just need to uprgrade all the internals input shaft output clutch flywheel forks synchros...i would just overhaul everything once your already into it
i was just going to go ahead and build my t 45 if its worth it, and i was just wondering i heard from a person that subframe connectors are only for solid rear end carsis that true or will subframe connectors fit on my irs
ya thats not true at all...my 01 cobra with IRS had subframes....i would most def get subframes with that kind of hp man...you gonna upgrade your irs and such maybe finding a junk yard solid rear would be good too
well i guess transmission is the last thing im going to worry about, i just baught steeda ud pullies, and steeda full length subframe connectors. do the subframe connectors hafto be welded in or is it just bolt on?
there is 2 diff kinds one that you weld in and another that you bolt in...i was always told that you should weld them in no matter what cause of the huge strains that they endure and to also have someone good do it so you dont pop welds youd be surprised how much work they actually do
Diode Dynamics
28
05-26-2022 12:02 PM
Greyshot
08-15-2015 03:32 AM
Boostaddict
Lethal Performance
08-13-2015 01:57 PM
