SVT Forums
Ran Cobra w/o Rear Belt
Old 08-10-2013, 10:57 PM
bluestang1724
bluestang1724's Avatar
Default Ran Cobra w/o Rear Belt
i just replaced my water pump and when i put everything back together I guess the rear belt (the smaller one closest to the engine) slipped off. The problem is the car ran for a few minutes before i figured out what the hell the problem was. I heard an odd noise and looked around for a bit trying to hear what it was, then i started to smell something bad and the exhaust started smoking really bad and smelled terrible. I shut it off and noticed the belt had slipped off.
How bad is it that the car ran for about 3 minutes without the belt on? Thank guys/girls
bluestang1724 is offline
Old 08-12-2013, 08:27 AM
Timspony
SVT Section Moderator
Timspony's Avatar
You should still be fine .... get the belt back on & get the car up to temp under idol only!!
Timspony is offline
Old 08-12-2013, 10:38 AM
bluestang1724
i got it back on and everything seems to be fine now. I let it idle for a good 15 min or so then took her for a quick spin. everything checked out good.
Old 08-13-2013, 11:50 AM
Timspony
Timspony's Avatar
Good deal
Timspony is offline
Old 08-16-2013, 02:44 AM
bluestang1724
Ok So i think i have a blown head gasket. I started the car today and white smoke plumed out of the exhaust. I mean it was rolling out. Then i started to see A LOT of water come out the tailpipes. I think the combustion chamber is leaking into the cooling system and that is what has been causing all my coolant problems and the excessive pressure in the system. When i open the radiator cap its like a volcano. Even after running the car for 2-3 min
Old 08-16-2013, 02:47 AM
bluestang1724
When i initially started the car after putting on the belt the 1st time i did hear a pop sound and a o lot of smoke. But after i fixed the pulley it all went away. And now today its smoking and smells like it did when the belt came off the first time
Old 08-16-2013, 02:49 AM
bluestang1724
I wonder if when the belt came off it didn't throw something off an caused the head gasket problem
Tivo304
08-28-2023 12:19 PM
2007CalSpec
12-13-2020 11:42 AM
11-10-2015 11:39 AM
StalkerGT
09-25-2015 02:41 PM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: Ran Cobra w/o Rear Belt
