The Racers Bench Is the track just too much for you? Want to know what will beat what? Talk about it here!!
First start of the 7675
Old 05-14-2014, 06:18 PM
  #21
TCStangerv6
TCStangerv6's Avatar
Originally Posted by Kerns
What was your issue with the wastegate and the converter?
well the tuner thinks I need to put the waste gate in a better place because I had a 3lbs spring in the gate with the boost controller set at 0 and made 16psi. They said it shouldn't of made that much. It should of only made around 5. As for the converter. They seen a loop on the graph. But they aren't sure if it was the converter or the tires spinning. I think it was the tires.
TCStangerv6 is offline
Old 05-15-2014, 05:27 AM
  #22
bluebeastsrt
bluebeastsrt's Avatar
Just curious, What anti lag are you going to be using for launch and what stall speed will you be leaving on?
bluebeastsrt is offline
Old 05-15-2014, 07:47 AM
  #23
Kerns
Kerns's Avatar
Probably just need another wastegate. Most likely isn't enough wastegate to bleed off the additional air.
Kerns is offline
Old 05-15-2014, 03:42 PM
  #24
Hangwire
Hangwire's Avatar
Why does it seem like Turbo/Wastegate systems are like mad science? With superchargers its easy....you install X.XX" SC Pulley with Y.YY" Crank pulley and boom you get almost the exact expected boost. But everybody always seem to have to play with their wastegate/tuning to get it right with turbos. Why isn't it very predictable? I assume the custom nature of turbos would effect this some.....
Hangwire is offline
Old 05-15-2014, 04:55 PM
  #25
TCStangerv6
another wastegate would work. But I want to save myself some money and just use the 46mm I have. Are you using one or two gates? Where are/is it located?
anti lag? You mean like a 2 step? If i get one it's going to be a N2MB wot box. But for now I'll be footbraking it to idk lol.
I was thinking this while it was getting tuned lol. Made me miss the YSI for minute.
Old 05-15-2014, 06:14 PM
  #26
bluebeastsrt
Ok so your not running a anti lag setup. I did use the n2mb 2 step on the neon. I gained 2/10ths on that.
Old 05-17-2014, 07:19 AM
  #27
ctgreddy
ctgreddy's Avatar
Have you contacted CG to see if he's heard of anyone else running into issues with his wastegate location? If this was a one off kit I'd be more likely to believe the location but a lot of guys run this hotside and I haven't seen anyone with an overboost issue.
ctgreddy is offline
Old 05-17-2014, 07:53 AM
  #28
BlindGUYnAR
BlindGUYnAR's Avatar
Remind me to never meet that car on a dark street.
BlindGUYnAR is offline
Old 05-17-2014, 12:47 PM
  #29
Kerns
Kerns's Avatar
I run one but I've had boost creep since I finished my build. I really need to just put a 2nd gate on it I'm pretty sure. I haven't really pulled the gate apart to make sure its working properly, but I'm pretty sure its just a matter of needing to vent more air than my RG45 is capable of.
Kerns is offline
Old 05-19-2014, 05:17 PM
  #30
TCStangerv6
I emailed him, just waiting on a reply. But I think a second gate is needed.
zsmart
Convertible Tech
02-29-2016 08:33 AM
1TUFF302
11-05-2015 04:02 PM
StalkerGT
09-25-2015 02:41 PM
dalefrancis88
09-11-2015 07:15 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: First start of the 7675
