SCT X4 and 4R70W - shifts at too high an RPM
I purchased an SCT X4 from LMR after my gear change from 3.27 to 3.73 to correct the speedo. From what I can see, the only way to make the speedo correction is to load a tune file. I loaded the 87 octane tune and am trying to get the transmission to shift like it did from the factory. This isn't a hot rod, it's a 2v motor with 194k miles on it. I've reduced shift pressure and that doesn't seem to help much.
The problem is that anytime I'm moving forward from a stop light at anything other than the lightest amount of gas pedal pressure it doesn't shift until 3k RPMs...way too high. Even at half throttle, that's pushing it IMO. Is there a way to change it to where it shifts below 3k RPMs under normal driving? LMR didn't have an answer and I called SCT and left a message but haven't gotten a call back. It makes the car not fun to putt around in. If I barely give it any gas, it'll shift fine but anything over light pressure and it's shifting about 3k RPMs.
The other question would be is there any way to just calibrate the speedo with the new gears and leave everything else alone?
As far as setting the gear ratio and tire RPM, you should be able to manually adjust those under the custom options. Do it after you load the tune so it's only reprogramming those parameters.
I would suggest either to take it to a reputable tuner (such as Pro Dyno) and get a solid tune written, or data log it and send the file to LMR so they can see what's going on.
The reason that your transmission is shifting like this is not because of your "shift firmness" option. The "shift firmness" option only controls how much line pressure is built up within the valve body to shift. This option does not control any RPM related shifting. The option that you need changed is also not normally available to the end user. As the end user you can control "WOT Shift Points" but you cannot control part throttle shift points and this is the option that is causing your auto to "feel" manual and rev too far under part throttle.
Again only a custom tuner/entity with access to the SCT full custom tuning software can control this option. I am unaware if they can make this option available to the end user. I would contact American Muscle/BAMA and request that they adjust this option to your desires. If they cannot/arent willing I would then go to a custom tuner such as the aforementioned Pro Dyno in Fort Mill, SC.
***Just as a side note: When I put my SC on and had it custom tuned on a dyno they also gave me similar part throttle shift points in my tune. If you dont let off it will simply run up past 3K. I happen to personally really like the feel of this tune though. Its actually a lot more manageable than you think. Though it may be a bit annoying try barely pushing the throttle - I promise you it will shift at 2K if you are light enough on the pedal and I have 3.73s as well.
Another option you have is what I use most often which is what I call "lifting." You simply run the RPMS up to about 100-300 RPMS short of where you want it to shift and lift your foot off the pedal(almost completely) and it will shift immediately. This gives it a very snappy and manual feel - I really like it and when I let people drive my car they love it and say "It literally drives like a manual without a clutch to press." People go from talking **** to wanting to drive it more.
The last option I like to use to have fun. With this option you can drive as spirited as you want and still have full command over the shift points despite all tune options. Its really simple....just up-shift the transmission by dropping down into "2" with your shifter for 1-2 shift and by locking overdrive out for the 2-3 shift. Depending on your power level/suspension setup/tires you can chirp the **** out of the 1-2 shift and 2-3 shift this way. I used to run 1st gear up to full boost and shift part throttle at 3k-3.5k and it used to completely loosen the rear end up before I upgraded it and that was only part throttle. Extremely fun setup for a street car.
I'm sorry to hear about the troubles you've encountered during the tuning process, I'm sure it is frustrating to say the least. I would get back in touch with the company that wrote the tune. As Hangwire mentioned, with the full SCT custom tuning software, they should be able to change the shift pressures and firmness more to your liking, and data log to see exactly what is going on.
I cannot speak for other companies, but with Bama X4 tuner, you can change the rear gear ratio without getting a retune. This can be done in the tune settings location.
I hope either SCT or the company you got the tunes can help you out. If not, by all means get in touch with Bama and we would be happy to offer our insight on the matter.
I hope this helps, and if we can provide any assistance feel free to get back in touch. Best of luck!
-Dan
Gadgetech. Can you shoot me PM with your information so I can look into this for you. If you have your sales order number add that in the PM, if not, give me your billing zip code with your first and last name.
Thanks
Thanks
Dan - you've always been a pleasure to talk with on here and you are very supportive even when I didn't purchase from AM.
Jarrod, I've pm'd you and thank you for reaching out. I've got a list of items that I plan to purchase from LMR, new convertible top hydraulic cylinders are next.
I'm learning some of the tricks you mention and honestly this would all go away if I'd just purchase the B&M hammer shifter. It's just one thing in a long line of stuff I need to do to the stang. I have a mental block with shifting an auto of this vintage...just feels like it isn't meant to do it on a regular basis. It's not the end of the world but it isn't what I expected and my wife doesn't feel comfortable driving the car...and doesn't want to "learn" the tricks. I don't mind doing something with pro-dyno but it's unbudgeted funds so I'll have to deal with whatever changes can be made in the short term. If none can be made, well, I'd rather have a correct speed than lower shift points. Thanks for your info, it is very helpful.
09-01-2015 08:16 PM
ericdiver
01-14-2006 01:21 PM
skunkanova
14
09-02-2005 03:12 AM
