Cutting Springs - No new Shocks/Struts
Old 10-09-2011, 03:35 PM
  #31
LilRoush
LilRoush's Avatar
I'd start there. You can always cut more if it's not low enough for you. The V6 weight and spring rating is different, so it won't be exactly like the Cobra.
LilRoush is offline
Old 10-09-2011, 04:02 PM
  #32
NewEdgeStang00
NewEdgeStang00's Avatar
I actually don't want it to be too low though, just about 1" or so but not more than 1.5" (also because I want to keep it in range of the stock Caster plates) but also want to utilize the stock struts for now, maybe pick up some Foxbody struts
So what I'm concerned with is cutting 3/4 off a coil, is it going to drop me 1.5" or more?
*and good to hear from you again LilRoush lol. Like the sig
NewEdgeStang00 is offline
Old 10-09-2011, 04:16 PM
  #33
LilRoush
LilRoush's Avatar
3/4 is a good starting point. It will be close without going over.
LilRoush is offline
Old 10-09-2011, 04:48 PM
  #34
NewEdgeStang00
The other question I have is how I should put the end of the coil back into the spring perch, since it'll be cut. Should I be "twisting" it so that the end of the pigtail sits exactly like where the original spring sat in the perch? Or should the spring be positioned the same as it was before it was cut? (Meaning that the end of the pigtail will be about 45 degrees back since I'm cutting 3/4's off the coil?)
Old 10-09-2011, 10:40 PM
  #35
Danielsmustang
Danielsmustang's Avatar
well look, i made the huuge mistake of cutting 2 3/4 in the back. it was the guys fault, i know you dont plan on cutting that much but just letting you know, my car is a BOUNCE HOUSE lol..
and when you put it back make sure to keep both ends the same, so that one side of the car wont be higher than the other.
dont be scared when your pushing down to take off the spring. use the end of the tire iron and have someone pulling the spring. the same person who is using the tire iron have him push down with his leg. try to keep the caliper held up when you take it off just in case, you dont want to break your brake line either.
cut the front springs at the same time so you make sure they are the same exact height, and same with the back.
Danielsmustang is offline
Old 10-09-2011, 10:55 PM
  #36
NewEdgeStang00
Well I was planning to cut 3/4 of a coil just off the front springs, because the back looks ok. As it sits stock the front end actually appears higher because of the wheel gap. As far as handling goes I wouldn't think that would present a problem
Old 10-10-2011, 11:24 PM
  #37
jthorn9
The Godfather
jthorn9's Avatar
I had a Cobra and I had to cut an entire coil off to drop the car 1 1/2" so that article isn't entirely spot on.
jthorn9 is offline
Old 12-18-2011, 10:36 AM
  #38
FOREVER UNFINISHED
FOREVER UNFINISHED's Avatar
Default CUTTING SPRINGS
I AM LOOKING TO DO THE SAME. WHICH END OF THE SPRING SHOULD I CUT. ANY PICS OF CUTTING SPRING. DOES THE POSITION OF SPRING MATTER. WHEN I DID MY TRUCK I CUT A FULL RING SO THE ENDS WOULD MATCH AS FACTORY.
FOREVER UNFINISHED is offline
Old 12-21-2011, 09:35 AM
  #39
brad2130
brad2130's Avatar
My car self lowered in the back...I think my rear springs are shot or shocks...Idk. I've never changed either or and I got 111,xxx on it. How much would some new shocks and springs cost? Would 500$ get me there? I work at wendys soooo its been taking me a while to save up some money for my baby
brad2130 is offline
Old 02-06-2012, 11:41 PM
  #40
SOCALBEAST
SOCALBEAST's Avatar
i have a 01 gt stock-
question for anybody with a vert who cut thier springs- how much did you cut and how much of a drop you get, i figured convertibles are heavier and might have a differnt spring rate. so lets give some verts some love.
SOCALBEAST is offline
CS2007
06-25-2019 09:45 PM
jrrhd73must
10-02-2015 09:17 PM
mdg
10-01-2015 07:04 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Cutting Springs - No new Shocks/Struts
